Question about Samsung Cameras
How to fix the camera lens focus?
I bought a portable camera lens from shoppingbag.pk for my Samsung mobile. Even if I am using the additional lens the mobile camera is not fixing the focus and the picture become blur while zooming. How can I fix the issue?
  • Anonymous Apr 24, 2017
    you should read this article it will help you
    http://usanewstime.com/2017/04/03/galaxy...
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Hello Guys, I've try this problem previously and here are some of tips that might helpful:
-Clear Camera cache and data
Here's how you do it...
From the Home screen, tap the Apps icon.
Tap Settings and scroll to 'Applications' section.
Touch Application Manager.
Swipe left or right to display contents of 'ALL' tab.
Scroll to and tap on the Camera.
Tap Force close button.
Tap the Clear cache button.
Tap the Clear data button, then OK.
Noted: Don't worry, none of your pictures or videos will be deleted, however, all your settings with the camera will be reset to default.
IF PROBLEMS STILL OCCUR, THE BEST WAY IS TO DO MASTER RESET:
NOTED: Make sure you make a backup of files you don't want to lose during the problem. Remember, all your settings, information, apps and files saved in the phone's internal memory will be gone. If the reset failed, then the phone has to be checked by a technician as it is a possible hardware issue.
Thanks for reading hope it would help.
Posted on Aug 29, 2017
    Sergeant:
  • 163 Answers
A phone is a phone
If a camera with a zoom lens focuses as it stops
Using a phone for a camera you will have limitations
Regards
Sir J D Hamilton Taylor
IQ 397
Posted on Apr 25, 2017
  • 76 Answers
SOURCE: zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
Posted on May 11, 2007
SOURCE: Black spot on picture
My Nikon was having the same problem with the stationary black spot. I used a can of Dust Off ( the original compressed gas duster). I just removed the lens and held the camera upside down (lens facing the floor) and blew my compressed air inside and my black spot disappeared. Just a thought you might like to know !! Good luck.
Posted on Jul 04, 2008
SOURCE: Fine-Pix A400 is showing Focus Error and will not
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Posted on Aug 12, 2009
SOURCE: vibration problem
Sony has recently discovered that with certain units of its "Cyber-shot" DSC-T20 digital still camera, a symptom may arise in which the camera body may vibrate when it is powered on, due to a mechanical failure affecting the lens, and it prevents the camera user from being able to shoot.
To ensure customer satisfaction, Sony will provide a free repair service when this symptom occurs within certain units covered by the serial numbers indicated in the serial number validation box below.
We apologise for any inconvenience this may cause. Your understanding and cooperation would be much appreciated.
Symptom and cause
The camera body may vibrate when powered on, due to a mechanical failure affecting the lens. This prevents the camera user from being able to shoot.
Applicable model
Digital Still Camera "Cyber-shot" DSC-T20.
How to check the model name and serial number
The model name and serial number are indicated on a sticker located at the bottom of the camera.
Applicable serial number
To determine whether your DSC-T20 camera purchased in Asia Pacific region may be affected, click here to validate the serial number.
Model Name Area Serial No. Range Unit DSC-T20/B AU2 2257001 - 2501900 5,050 DSC-T20/P AU2 2258851 - 2485700 4,700 DSC-T20/S AU2 2261851 - 2501500 7,650 DSC-T20/W AU2 2265751 - 2502100 7,650Period of free repair service
From 17th July 2008 to 16th July 2011.
PLEASE NOTE these serial numbers are applicable to ASIA / PACIFIC check your own country sony website if your serial number is applicable as different regions will have different serial number for the DTS -T20, hope this helps
Posted on Feb 03, 2010
  • 6 Answers
SOURCE: Canon SD1000 blurred pictures and blurred LCD, Camera wont focus! please help ive had it for 2 weeks
The best chance to use your SD1000 is to set to picture, push ISO (on top of the func. set ring) and set to hi. This works pretty well. Do not bother sending any camera to Canon, they charge the "standard charge" plus for all their manufacturing problems on all Canon cameras. Definately the worst customer service on the market.
Posted on Mar 19, 2010
Cannon T6 DSLR kit how it works
You look through the lens at the subject.
If the lens is set to autofocus, it will focus when you use the shutter button.
Aug 02, 2017 | Cannon Cameras
Adding a lens to my camera
To be sure you can use the lens, buy a Canon EOS lens. The plastic ones, can be cheap. I bought my last lens 28 - 80 mm, couple of months ago, for 5 dollar. and a working EOS 500 was connected for the same price. (lens and camera are still in good working order) Don't try other brands, because even when you find a convertor, it could be the lens will only work on manual focus.
Jan 25, 2014 | Canon EOS Rebel 2000 35mm SLR Camera
Parts praktica bc1
The praktica BC1 camera uses a bayonet mount described as PK. You need to search on ebay for "PK to EF adaptor". You will get plenty of results. Make your choice depending on whether you want focus confirm or not.
Dec 17, 2013 | Canon Eos Cameras
Panasonic LUMIX 14-42mm GX VARIO PZ lens on GF-1 Body
When using different lenses, a few things should be kept in mind.For some you need an adapter and not every lens ail work as the lenses made for this camera. Sometimes focus or other things needs to be set manually. So even when you can connect a lens to the camera you don't have any guaranty it will work fully automatic and correct. Please read the manual tag came with your camera, about the differences between the four thirds cameras and lenses.
Dec 03, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
How to use Nikon Pk-3 extension tube?
It should work with just about any lens, though it works best with moderate focal lengths (say about 24mm to 200mm). Its primary purpose is to let the lens focus much closer than normal.
When you say "no results," do you mean it's not letting you focus closer? Mount the tube on the camera, mount a lens on the tube, then focus the lens to its minimum focus distance. Looking through the viewfinder, move closer to an object until it comes into focus. Does it come into focus? How close? What lens(es) are you trying?
Jan 03, 2013 | Nikon Pk-3 Extension Tube Make Lens A...
Lens Error
well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Lens is stuck, and won't focus...
how to solve this cam yesterday cam slip from my hand so not working i buy from saudi arabia 2 month before so i want solve the problem
Dec 10, 2008 | Samsung Cameras
Focus with polarizing filter
No, the problem is not with the lens. Your Canon camera requires unpolarized light to focus. Even on manual focus, you may have trouble seeing focus through the viewfinder. That's why they invented circular polarizer.
Sep 29, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Compatibility of vivitar lens with Minolta x370
Minolta X 370 is not an auto focus camera so provided you are willing to use the Vivitar lens in manual AND provided the lens has minolta mount , you will be able to use it.
Sep 04, 2007 | Cameras
Cameras Logo
116 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
