Vehicle Parts & Accessories Logo
Phillip E Haney Posted on Apr 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I hook up a sensor and trigger input on a crimestopper alarm SYSTEM AND REMOTE START MODELnumber RS795VAT
Rodney Schmidt
Level 2:
Sergeant:
  • Expert 240 Answers
  • Posted on May 08, 2017
Rodney Schmidt
Expert
Level 2:
Sergeant:
Answers
240
Questions
0
Helped
69945
Points
778
What sensor are you wanting to hook up? Does the sensor have a pre-warn feature, or is it a 2-stage sensor? These have an extra wire compared with a single stage sensor.
5 Related Answers
Anonymous
  • 1111 Answers
  • Posted on Sep 09, 2009
SOURCE: 2000 Chevy Impala, alarm remote issues
you should be able to however im not sure if it is associated with the on board system if all else fails reconnect it and maby change the batteries in the remote for a starting point
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Sep 19, 2009
SOURCE: will my 97 eclipse gst need a universal bypass
forget the boy racer alarm ,it will cause no end of problems in the future ,just use a padlock and chain from the seat fixing and then around the steering wheel ,check this site out for people with problems big time from these alarms being fitted.
Anonymous
  • Posted on Dec 16, 2009
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Anonymous
  • 20 Answers
  • Posted on Feb 09, 2010
SOURCE: I have a crimestopper security system and the
if the battery keeps dying on your remote it probably has a bad contact somewhere inside you could order a new one from www.crimestopper.com you would have to have your unit model number for them to help you that is located on the unit under your dash
Anonymous
  • Posted on Oct 31, 2010
SOURCE: erratic security system goes off for no reason and
that happened 2 me , had 2 have it towed to dealer. I had them disable entire security system.
2answers
2001 GRAND PRIX FACTORY ALArm goes off ramondly
i will assume you want a real answer not wild guess
or the captain obvious get the car serviced.
own or rent the scan tool, is best !!!!!!!!!
PONTIAC GP
JUST after OR during it alarms scan the PCM for DTC errors based on alarms.
WHY SKIP THE SCANS, OBD2 PORT,? USA CAR?????
How to wire a sensors and siren to a RS795VAT REMOTE START AND ALARM
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
Crimestopper sp-101 car alarm
First coneckt the power direct to batery
My Viper Alarm started going off while I was driving. I pulled over, shut everything off. Got out of the car and closed the door and locking and unlocking the vehicle wouldn't shut the car off. I opened...
The alarm may not be going off. Rather it may be a malfunction of the relay that is driving all the sirens and piezo. Next time it happens check for flashing parking lights. They will flash only when alarm is going off. Also ignition input to the alarm prevents this alarm from going off while driving. Panic from the remote can still be triggered. Got to play detective....
I have a 2011 doge avenger with stock alarm and 504k shock added. when i remote start the car the horn blows for 2-3 secs. turning off 504k stops this. help
You are having this problem because the OEM alarm will shut off your engine and trigger your alarm when the hood is opened. Your 504k sensor is connected to your hood, so when you start your car remotely, the vibration is triggering your shock sensor and thus triggering your alarm. I had this same problem. You need to reduce the sensors sensitivity dramatically to help resolve this issue.
I have a Avital model 4100 remote car starter. My question is I have 2 wires that i cant figure out where to or what to hook them up to. The wires are on a 9 pin connection. They are the H1/4 White/Blue...
I'm not familiar with this particular model, but do you have the wiring/installation diagram for this system? If so, does the manual specify if these are trigger wires or if they are output/source wires?
They could be trigger wires to allow a secondary system to activate the remote start and they provide options for either a negative trigger or a positive trigger. They could also be outputs that will provide a negative signal/pulse or a positive signal/pulse to activate other features when a remote start is successful (such as to activate a relay to power the heated seats).
1helpful
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
