"May you please show thee complete wireing-diagram-for battery charger" 520A-PE highly appreciated ,sincerely your friend
  • Reye Diaz Apr 22, 2017
4 Suggested Answers
SOURCE: Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Posted on May 30, 2009
  • 492 Answers
SOURCE: I need to see a wiring diagram of an MPX 210
It really depends on what subs you are mounting in the box. If you are mounting single voice coil subs, it's easy. positive of the sub goes to positive on the inside of the box and the negative of the sub goes to the negative of the box. Then you would repeat the process for the other sub. Then wire the box to the amp using the push or screw terminals.
Now if you have dual voice coil subs, that's where it can get tricky. You really have to know what amp your using and what ohm load it can handle, and how many channels you will be using.
I'm going to give you an example that has two dual 4 ohm voice coil subs. Let's assume you will be hooking them to a 2 channel amplifier that is 2 ohm stable.
wire the positive of both voice coils to the positive post of the box. then wire both negatives of the voice coils to the negative of the box. Repeat the process with the other sub. This is called a parallel set up. Two 4 ohm voice coils wired this way will produce a 2 ohm load. since your amp is 2 channel, you will hook the positive and negative to the positive and negative of one side of the box, then repeat with the other channel to the other side. This will allow the most power to come out of a 2 ohm stable amplifier.
If you have something other than the equipment I gave you an example of, repost with your equipment specs and I will walk you through it.
Posted on Sep 10, 2011
Testimonial: "Thanks. That helps. I understand about the ohms and the channels. They completely bi-past the amp in the box. Also has 2 mid and 1 piezo tweeter."
  • 61 Answers
SOURCE: show wire diagram for AL 1115 CV CHARGER
WeIl I dont know the language but the rest makes sence, 0749d6a5-1dbe-4a91-85d2-5ce491855854.jpg
Posted on Jun 05, 2014
I need to know if someone can help me on where I should start or where to look at 1st. I have low beams&no high beams someone said the wiring is messed up or its bad& it drained my battery completely
You need to look at a wiring diagram an test the lighting circuit . A wiring diagram shows what wire is what by color coding . You can find a wiring diagram at . You can go on your tube watch videos on basic automotive electrical trouble shooting , how to read wiring diagrams . No one on here has a magical answer ,your only going to find this problem looking at wiring diagram an tracing out the wiring .
Mar 03, 2016 | Cars & Trucks
Digital camera battery, camcorder battery and charger online store -...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 21, 2010 | Computers & Internet
How can I get rid of the loud squeak in my Jenn-Air oven door?
Digital Camera Battery, Battery Charger Online Store. Canon, Panasonic, Samsung battery and charger online store - is a sincere, trustworthy E-Commerce website since 2006. Provide cheap high-quality replacement battery and charger for Canon, Panasonic, Samsung, like:
Jun 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I have a 5000 w maxa ER generator that has a battery assist added ( PM 0525312.17 ) Question...Is the battery a regular 12v car battery, or maybe a lawn tractor battery?? Once the generator is started...
Replace battery with your choice of 12v products considering physical size, amp range and warranty. Lawn tractor batteries seem to have the least life/duty cycle. There are two methods of charging the battery used by Coleman. One is to charge the battery with charger/alternator coils installed under flywheel of the engine and second is to charge with built-in circuit in generator itself. Examine your wiring diagram to discover which you have. Simple test with volt meter will show if system is charging. Test voltage at battery with engine off, then start engine and retest looking for slightly higher voltage indicating charge. The charging system is like a trickle charger and not like your auto with initially high amp charge then taper to minimum. If your run your generator for long periods of time and you feel that the battery is being overcharged, then rig a switch to stop charging after one hour or longer. Good holiday
Nov 27, 2010 | Coleman Powermate Powermate 5000W...
The instructions say the Honeywell DT92E needs only a two wire connection, but the wiring diagram shows three, which is correct Please
This Honeywell control thermostat is made for wireless control, by means of a relay control transmitter with a range of 30 meters. It only needs a 2 wire connection on this stat if indeed it is the DT92E stat. Even though the diagram shows three, you will need only 2 for operation. This is a fact. I have done some reading on this model and many of its relatives, so with built in relays, and transmitters, this is an amazing set-up. Good luck with it as you should enjoy its operation and user friendly features.
A/C, Heating, & Refrigeration Contractor
Please be kind when rating, as I know you will be. If you have anymore questions, leave them in the comment box so I can check in when I can get to them. Thank you for using
Nov 20, 2010 | Heating & Cooling
Can't turn on and a battery sign with a red slush appears
Thee battery is fully discharged. It may take an hour on the charger before this goes away.
Mar 13, 2009 | RIM BlackBerry Pearl 8100
Wiing diagram clarion PE-2528-KA needed
Can you please send me the wriring diagram for a clarion pe-2528-ka radio/cdplayer.As it has been taken out of the car and the wires were cut. I need the wriing to put it into another car. Thanks Glenn
Feb 28, 2009 | Car Audio & Video
Sidekick LX keeps shutting off and coming back on repeatedly
new beattery
or new phone.
batteries are cheap on ebay, , dont have a visa? just buy a ebay gift card from target..ect and then usee that too payy thee item off!
call tmobile 18777782106 dhats thee teechnical support line
Oct 01, 2008 | T-Mobile Sidekick
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
