Question about Facebook Computers & Internet
How long is the Swiffer Wet Jet expected to last? I used the regular Swiffer on occasion years ago and now after about 12 floor moppings I remember why I never bought one again. So how long ?
The handle breaks in the same place Everytime. I can't find one friend who has one that's not broken in at least the upper portion where it connecrs! Not one! Im considering a Facebook survey......
  • Facebook Master
  • 397 Answers
You can go through this link may the resolution can help you. Top 184 Complaints and Reviews about Swiffer
Posted on May 24, 2017
  • 1554 Answers
SOURCE: whirlpool duet washing machine dooe handles
as you say the door sticks ,
so the handle is not the issue ,
your latch is ,
either it is not lubed or out of line .or has some plastic damage inside it,
it should only take a few ounces of pull ,
use your pinkie and only a small strain and its open.
any more and you have your issue .
its the latch.
unless its rubbing around the other plastic panel parts nothing should touch.
Posted on Oct 31, 2008
SOURCE: Reset my RadioShack Wireless Security System Console 49-1000MC
Hey, Mine did the same thing, this is what I did. I entered "0000" for the pin and was able to reset the unit (0000 is the factory default) It may not work for you, but it's worth a try.
Posted on Nov 10, 2009
  • 175 Answers
SOURCE: should i use regular tap water or distilled water.
Use distilled water or you will have a future clog of hard scale build up in your machine.
Posted on Jan 01, 2010
SOURCE: Dirt Devil Deluxe Easy Steam Mop won't steam
Hi Slatts51 I am having the same problem it worked wonders the first time I used it, now its doing the same thing as yours, I can hear it gurgling and sometimes it will emit steam but hardly like before, I think I might be switching to a different steam mop I contacted the company now it will take a few days for someone to contact me back, go figure.
Posted on May 27, 2011
SOURCE: My SteamTek floor mop will
can I put vinegar in the waterf to get rid of the rust I see on the outside or,,,,,,,,,
Posted on Jun 23, 2011
Change battery in wet jet. Where is battery located
Just under the bottle, where you see the letters CE, there is a green tab.
Push it down, and the cover comes out.
There will be 4 AA batteries inside.
Be sure to put them in with the correct polarity. It is marked in the diagram inside the door to the battery case.
Dec 16, 2017 | Swiffer WetJet Spray Mop Floor Cleaner...
Swiffer wet jet stopped working.
Check the battery output, or take your jet to someone to open it for you to check the connections on the battery slot.
Jul 14, 2017 | Cameras
Can I safely use the Shark pro Steam Pocket mop S3601 on dark hardwood floor?
You will not hurt your finish by using the steam mop...use it without any type of cleaner on the mop head and you should get a great streak free shine...
Jan 07, 2015 | Shark Vacuums
How do I properly maintain cork flooring?
You should mop regularly with a damp mop in order to keep your floor clean. You should avoid using cleaning agents and you should also avoid over-wetting your floor.
Feb 06, 2013 | Building Materials
My brand new h2o mop won't steam. Green light comes on and thats it.
bought it a few years ago - I used it a few times and it was fair but did leae a lot of water on the floors. My wife had wanted it as it was supposed to be a miracle device, but she had some health issues and not able to do heavy housework. She is better now and decided to try this miracle device she had wanted so bad - so we took it out and no steam - so this would be it's 3rd use and it's was dead. I'm a bit of a tinkerer so decided to take the thing apart/clean the nozzles etc per the troubleshooting guide. Well, none of the obvious/accessable nozzles were clogged, and the filter seemed to pass air and water ok (probably does have to be changed due to time vs uses. Anyway, took the unit apart and ended up having to take the pump motor apart - there is a little nozzle/connecter on the back of the motor that passes the water into the heating chamber. cleaned that with a pin - put it back together, and tons of steam shooting half way across the room. So - she did the floors, they are wet but clean. Bottom line - does an ok job but leaves a lot of water behind, and it appears the internal nozzles can be a problem, and not something the average householder would want or be capable of fixing. (they do say you can try using WD-40 in the unit to clear nozzles - not sure how it would get through to the pump nozzle, but maybe this would work ??
Anyway - may end up buying some more filters as we will want to get a few more uses out of this thing for our $100 bucks, but will stay away from them in the future (go back to the wet swiffer - does about the same job but much less cost and hassle).
Mar 07, 2011 | H2o TR220002 Steam Cleaner
My machine unable to complete program its saying check coin trap? where is the coin trap?
To find your coin trap:Loot at the front of the machine, and at the bottom-left is the coin trap.Put towels in front of the machine to mop up any water (it's going to get wet).It opens anti-clockwise (remember righty-tightie, leftie-loosey), but you need to move the little bit of yellow plastic (12-oclock position) up first. The machine dose come with a little tool to do this, but you may have lost it. You can move the bit of plastic up by carefully using a flat screwdriver, and turning the round plastic with your other hand. Don't force anything. After you remove it, just swim over to your machine and remove the yellow thing in the middle by pulling it gently towards you. Clean out the coins/paperclips/buttons that you find in there.Push back on the yellow bit into the coin tray, tighten back on the cover the coin tray (the yellow thing at the top will 'click' back).Using a mop, take the opportunity to clean the kitchen floor now that it is all wet.
Feb 26, 2011 | Dyson Memory CRO1 Front Load Washer
We are VERY disappointed in our Steam mop. After only using twice in one year and following all the instructions, went to use it yesterday, Oct. 7th and could not get any steam out? It started up and it...
Unfortunately they do not work well at all but if it means anything to you your not alone. Many people have complained about the same issue. To be quite honest there really is nothing better than very hot water in a bucket with a bit of cleaning solution and just be sure to squeeze out the mop well before you put it on the floor. It does not need to be sopping wet. Steam, is just water anyways and you can get steaming hot water from your tap in the house bso really its no different.I hope you kept the receipt so you can return it. I hope I didn't ruin your day and if this did help be sure to remember to click on the yes bow on your way out . Thanks again and good luck.
Oct 08, 2010 | Vacuums
Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Computers & Internet Logo
130 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
