Question about Samsung Cell Phones
Samsung galaxy elite. strange picture showed up. Covers almost entire screen. Small area down left side where you can see that the apps are there and can change screens but cant get rid of pic
  • 1694 Answers
SOURCE: 40wh08b convergence problem
Convergence IC's need replacement = STK392-110 original #...
Use name brand Toshiba, NAP, or upgrade to STK394-160E
Hitachi part # CZ cheap generics..they won't hold up..
Chassis pull and some precision soldering will be needed....let me know if you need further info...........................T.
Posted on Dec 27, 2007
  • 19396 Answers
SOURCE: not showing entire image on screen
The lens may be out of place, I will see if I can find service manual or diagrams to disassemble the projector safely and fix the problem.
Posted on Feb 18, 2008
  • 76 Answers
SOURCE: My new Samsung LE32R88BD was
I did some reading on the net, try to "calibrate the screen". Try set the input to 1080i, then run the thx optimiser to give you a starting point, then try a bluray with a bright image.
Keep replaying the same chapter and try raising and lowering different settings. you may find that your brightness is set way too high and after dropping it from 90 to 29, you may find that detail will have crept into the image. Try giving the colours a boost as well.
The detail in HD is very subtle, and having a properly calibrated screen will make all the difference. So to answer your question: set your input to 1080i, make sure your HDMI is outputing RGB and start tweaking that screen!
Posted on Mar 08, 2008
  • 8457 Answers
SOURCE: Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Posted on Dec 15, 2009
SOURCE: I have a 40" Samsung
Call Samsung (1-800-726-7864)about the problem. They are aware of theproblem and offer a 1 time free repair. Therepair is generally done in your home. Samsungdid tell me that they even take care of the bill outside your warranty. I hopethis helps
Posted on May 04, 2011
Where is calculator?
Samsung Galaxy Note 3: Where is the Calculator app:
Hello. The calculator app is in the "App Drawer"
Tap on the square image at the bottom right of the screen
dont-know-calculator-phone-kyzl0pi20tqzz121bvlihxv0-3-0.jpg Scroll to the left or right to get to the screen that has the calculator on it.. This could be in alphabetical order
Feb 06, 2016 | Samsung Galaxy Note 3
How to Close Apps on a Samsung Galaxy
1) Go to the Home screen of your Samsung Galaxy device.
2) Press and hold down the "Home" key on your device. This action will display a list of all applications you have recently accessed.
3) Review the list of applications to determine which apps you want closed.
4) Tap and drag each app you want closed to the right or left. The apps you drag off-screen will automatically be closed.
  • If you want all apps closed, tap on the "Remove All" icon located at the bottom right corner of your screen.
on Jan 10, 2015 | Samsung Galaxy Cell Phones
We have a blue flashing light at the top left hand side what is it for and how do i turn it off
Samsung Galaxy S4: Flashing Blue Light:
Hello. By default it means that you got a text message or some kind of notification. If you are on the home page after opening the lock screen and your text messaging app doesn't show that it received a text message (if it shows it received a message there would be a one next to it, near "Messaging" app)
blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-0.jpg Then, with one finger.. touch the screen at the top of the phone and move finger down the screen (while still touching the screen).. you should see the notification area.. under the settings of that area it will show what is alerting you:
notification screen:
blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-5.png If you still want to turn this off.. go to:
Settings>Device>Display>uncheck LED indicator:
Feb 01, 2016 | Samsung GALAXY S4
How to delete unwanted music
is it a galaxy samsung tablet ?
in apps find an app labelled as my files with a folder icon above it
under root/sdcard/music
find music file click on the little box left of the file you wish to delete
a green tick will show in the box
once you do that you will notice at the top of the screen a dustbin icon has appeared in the right top side. press this icon to delete the file. then click on yes when it asks if you want this item deleted.
Then double click back icon to get out of my files
back icon is bottom left corner on black part of screen.
Mar 18, 2015 | Samsung Tab Tablets & eReaders
How do i turn off safe mode on a samsung galaxy ace
Safe mode in Galaxy Ace s5830
To START "Safe Mode" use both hands to Press the Home Key (bottom centre) and then simultaneously Press BOTH the Power (right hand side) key, and the Volume-Up (left-hand side) key. When the Samsung Galaxy logo appears, release the sides' Power and Volume-Up keys but keep the Home key pressed. Safe Mode should come on shortly. SIMPLY DOING THIS SAME KEYING SEQUENCE, WHILE THE PHONE SHOWS "SAFE MODE" IN THE BOTTOM LEFT CORNER OF THE SCREEN, SEEMS TO TURN THAT "SAFE MODE" OFF. Safe Mode prevents Third Party Apps running, apparently.
Apr 18, 2012 | Samsung Lands Phones
I have a Mitsubishi 52628 that has a strange pattern on the left side of the screen.
I had this strange occurance too. It appeared right after I connected the antenna wire so I changed to another style input and got the full screen shot. i did not investagate the input on the tv further as I had other connections i was able to use. I hope that helps with yours.
Jan 31, 2012 | Mitsubishi WD-52628 52" Projection HDTV
How do i use nite vision on the Samsung s galaxy for her AT&T which has no flash
Open the camera app.
Then on the left hand side press the "SCN" scene select button.
Look for the scene mode labeled "Night". Press that "Night" icon twice.
It will return to the taking pictures screen - now in night mode.
Mar 14, 2011 | Samsung Cell Phones
Hang Up & Sometime Touch Problem
hi all, i need help.. my samsung jet keeps hanging suddenly since yesterday. the touch screen won't even work even when i removed my batt. the phone becomes very lag.
also, the miss call alert will expand itself and the whole phone will hang again..
any suggestion?
Jul 23, 2010 | Samsung Jet S8000 Cell Phone
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
