Question about Asko Dishwashers
Our asko d5424 got stuck on a cycle and now neither the start/stop button or the program button will work.
  • 3 Answers
SOURCE: Asko Dryer stops running when you release the start button.
It could be that the overheat protection kicked in. When this happens the dryer will start when you push the button but shuts off when you release it. There is also no heat.
There is a reset button on the back of the dryer covered by a rubber membrane. Push that in. If you hear a click, the dryer has reset and should run normally. If the dryer continues to shut off and need reset, there's probably a lint blockage somewhere.
Posted on Jun 21, 2009
  • 2187 Answers
SOURCE: Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Posted on Oct 09, 2009
  • 2605 Answers
SOURCE: Asko Dryer t760 program menu
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Macmarkus :)
Posted on Sep 18, 2010
  • 4399 Answers
SOURCE: Hi, my Asko W6011 Quattro
Thanks for choosing FixYa and welcome.
Posted on Jun 06, 2011
  • 2605 Answers
SOURCE: built in asko dishwasher lights
Hello, welcome to FixYa.
Based on your post I understand you have an Asko dishwasher, first off I'd like to verify the model number and second the symptoms or status.
You said the lights along the top do light. yet the unit will not start when you select a cycle and the door is closed, correct ?
There are a few possible scenarios (depending on the model of Asko) so I'll need to clarify the model before moving forward. Anything thing else you can add is beneficial.
Macmarkus :)
Posted on Jun 17, 2011
Asko D5424 water not going in to diswasher
sounds like the water inlet valve is not working. it is not real hard to replace.
Jun 01, 2014 | Asko 24 in. D3120 Dishwasher
Asko washer W6324. Ran two loads with no problems. These used the SANI setting (wish I could control the water temp by temp settings and not fabric descriptions). New load of delicates. I set it to woolen...
Try to press the start/stop button for at least 3 seconds. This should reset the started cycle, and you can make a new choice. If this dont help, it could be a faulty control board
Sep 29, 2013 | Asko Washing Machines
D 3100 continues to pump out. Program stops and program button flashes
We have just fixed our Asko 3100 dishwasher. You need to undo the screws attaching the unit to the side cabinets. Pull dishwasher out and tilt forward to drain. Put towels down as lots of water. Machine seems ok now and running on a cycle.
Nov 06, 2010 | Asko Dishwashers
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Unable to reset wash program
Press and hold the start/stop button for a few seconds.
Nov 25, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Open Questions:
Dishwashers Logo
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
