Question about Dolphin Pool & Spa
Dolphin stopped running. Haven't had it for 2yrs Motor not working. I'd this covered under warranty
    Top Expert:
  • 12,744 Answers
Need to notify manufacturer about the warranty and whats covered
Posted on Apr 21, 2017
I have a Dolphin Dx3 about 4 months old. It has been working great, but now when I press the button on the power pack to turn it On , the blue lights come on which means it is On , but the impellor only...
Thank you for posting your question here on
For starters, try the tip I posted here on Fixya, found at: If that is not enough, try our sites FAQ section on Dolphins at Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit.
For units still covered under warranty you should first contact Maytronics for directions. They can sometimes troubleshoot the problem over the phone but if the issue is beyond simple phone support they can start the process of getting the unit repaired thru a warranty center which we are.
To contact Maytronics call 1-888-DOLPHIN or try their website at: If directed to us in Michigan our site is found here:
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Mar 30, 2011 | Dolphin Pool & Spa
My dolphin advantage runs for a few minutes in each direction but then stops. When I reset it the impellor runs but the machine does not move, then all stops. What is happening?
The motor unit inside is probably failing. When the drive motor and/or impeller motor move you can assume the power supply and cable/electric connections are ok. Whether the unit is in or out of warranty you can either send it to a service center (which we are one) or try to repair it yourself. The motor unit for that cleaner is about $400 and when installed by a non-service center does not come with a warranty so you are better off sending it in for a complete diagnosis and estimate. For information about the repair and sending it to a center you can contact Dolphin direct at or our site at
Jun 13, 2010 | Dolphin Maytronics Diagnostic Robot...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
The unit (6 years old) stops after a 30 sec. After rearming I can start again, and again, and again. Because the unit is no longer under guaranty, I disconnected the motor unit. By testing it (beside the...
Running it next to the pool is not very telling as it will shut itself off in that time anyway. Do you have access to another power supply to try with it? It is possible, though unlikely, it is the problem. It is more likely the motor pack and a new one is costly. If you would like parts or a quote on a motor replacement, use the dolphin contact portion of our website at
Sep 01, 2009 | Dolphin Maytronics Diagnostic Robot...
The robot only works for about 10 minutes then stops.
For warranty and non-warranty repair service contact us using the dolphin service form at or you can try the manufacturer at
Jul 20, 2009 | Smart Pool Inc Dolphin Diagnostic...
I have the exact same problem with my unit!
It is probably the motor unit and should still be under warranty if it is less than 2 years old. You can use our Dolphin service form at or contact the manufacturer at for service information.
Jul 12, 2009 | Smart Pool Inc Dolphin Diagnostic...
Runs slow then stops for no apparent reason
You can contact us at for service. There is also a FAQ for Dolphins in the FAQ section.
You can also try the manufacturer at for answers. It may be the power supply but is more likely an issue in the motor pack. It may still be under warranty depending on the purchase date and model. Some have 3 year motor warranties.
Jun 30, 2009 | Smart Pool Inc Dolphin Diagnostic...
Having problems with my dolphin diagnostic explorer robotic pool
Your motor unit was covered for up to 3 year under warranty. Confirm your warranty status at and perhaps the repairs are still covered.
Mar 08, 2009 | Aquabot Robotic Pool Cleaner
Pool & Spa Logo
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
