Question about Vacuums
How do i fix this problem rug dr shampooer leaving water in the carpet
There is good suction from the hoses but no suction from the base that touches the carpet
    Master:
  • 482 Answers
Hmmm thats a lil odd may need to check the connections to the hose and to the floor unit of the vac for any damages or other issues
Posted on Apr 22, 2017
  • 112 Answers
SOURCE: Kirby shampooer
here are instructions with pictures of how to put the kirby shampooer together...
http://www.greatvacs.com/shampoo.shtml
hope this helps!!!
Posted on Mar 28, 2008
SOURCE: Eureka Atlantis Rug shampooer wont
make sure that the two slide-tabs on the front of the machine are all the way down so that they can hold the front see-through cover down and create suction at the front. I did the same thing. you can tell when they get moved while cleaning because you will hear a muffled pop like something just got sucked into the vacuum. It is just the sound of suction being broken.
Posted on Aug 29, 2008
SOURCE: Need a user manual for the Electrolux Floor Pro Rug Shampooer
Found a manual on the internet so do not need any assistance.
Posted on Mar 20, 2009
  • 7 Answers
SOURCE: kirby sentria carpet shampooer
you dont **** out the water....if you use the reccomended Kirby shampoo there is no need to **** out the water because it is a semi dry liquid ...it will dry by its self in about 1 hour....I,ve been with Kirby for 16 years now ...i will know
Posted on May 19, 2009
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfhjdhg
Posted on Sep 30, 2010
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
Very little suction leaves rug wet.
Check tank and tubes for clogs. Make sure your belt and brush are working. Also make sure you are not overfilling your tank.
Proheat 2X Shampooer Shampooer Parts
800-775-6586
GoodVac com
Feb 24, 2015 | Bissell 2X Proheat 9200 rug cleaner
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The hoover shampooer will not extract the water from carpet, is it because the carpet is so low ?? the carpet is cleaning fine there is VERY poor underlay and then wood under that, worried about the wood...
do you have suction at the front of the base,if you don't then look at the plastic cover on the base,you should be able to see through the plastic.the suction slot on the bottom front of the base is very narrow.i don't know if you have pets but most of the time the suction chanel gets clogged with hair and dirt.the chanel is right up the middle on top of the base.look in there and see if you don't see a lot of hair and dirt stuck up inside.there are some screws on the bottom that you need to take out to remover the cover.then the cover comes apart in two pieces to allow you to get to the suction chanel.please leave some feedback.i hope i was some help to you
Apr 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
Carpet steamer does not **** up the water
take a look at the back side of the suction of the unit. first there's thre ront pies\ce of plastic then there is another. somtimes the secind piece becomes broken and the suction of the unit is wiped out.
Jan 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Cant get rainbow shampooer to work
use the suction port for the vac hose
the water hose hooks to your kitchen faucet
Nov 11, 2008 | Rainbow E series Canister Wet/Dry Vacuum
HERE is the shampooer manual. There is no suction involved picking up the water. It simply scrubs the solution off the rug and throws it in the tray in front of the Kirby vacuum.
Jul 19, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
