I have my cable connection run thru my DVD player to a Sharp 46" plasma TV. The DVD has always played fine in this mode on TV Input Source. Just recently I got this "Failed to receive broadcast (E202 message)". DVD won't play, but the cable signal flows perfectly thru the DVD player to the TV. I've checked connections -- all good. Any ideas? Thanks.
  • 10,594 Answers
Seems system control detected problem in cable signal and generated that error message that need to reset. Please unplug DVD player from wall socket for couple of minutes to get it reset, replug back in and turn it ON.
I hope problem will solved.
Thanks.
Posted on Jul 24, 2009
Dvd to tv I have audio with no visual
How do you have the DVD player connected to the TV? My dvd player has component video out; when I accidently swapped the green and blue RCA inputs, I had no video but the audio was fine.
Thus, check your cables and make sure that they are all connected to the matching input and output. You may want to try a different cable, in case one of the wires is damaged.
I hope this helps.
(You can also try connecting a different device to the TV or the DVD player to another TV to check if the problem is with the TV's inputs or the DVD player's outputs.)
Nov 23, 2012 | Sharp LC46SB54U 46 in. LCD TV
I have a Sa-ex900 amp hooked up to Television ,vcr and dvd player. When I turn the amp on and want to play the tuner , the television bleeds through. In fact TV plays through all buttons except VCR1
it seems to be ,you have a possible wrong connection..I
may I recommend you to check the connections in accordance with my model connection procedures given below and correct if something is misconnected..
I believe Your Television ,vcr and dvd player all connected to each other thru Technics Receiver itself (not directly connected to each other ) and whenever you want to listen/watch any of it ,you make a selection thru Receiver..
** in order to do this both DVD and VCR 's "2xRCA audio" and "1x RCA Video" cables for "IN" and "OUT" should go to Receiver separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected )
** Additionally your RECEIVER's prefably only "1xRCA Video Output " should go to TV to watch the video of both DVD and VCR (audio will come thru Receiver.)
Ok, now Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV .( every TV has different type of Audio out jacks )
** to "TV input "or "AUX input" or "Optic Cable input"
of your Receiver (whichever you want ,based on the necessary cables on your hand )
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..Tv sound are on the
Receiver .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 07, 2011 | Technics SA-EX900 Receiver
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
I set up my 42 inch Insignia plasma, turned it on for the first time (connected to a DVD player in AV mode) and can only get a black and white picture, no matter what I connect as an external source.
Make sure your dvd player is not in progressive scan mode if your using a/v mode. The best way is RGB component input, provided you have the cables.
Nov 27, 2010 | Insignia NS-P42Q10A Plasma TV
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
