Question about Garden
Tractor wont start. has new battery, turns over. Black soot blow out of the exaust
  • 342 Answers
Sounds like its been burning oil. Maybe a de coke is whats needed. Take it in for a service.
Posted on Apr 22, 2017
Soot and water coming out exaust,is my exaust manifold gasket the problem
You got a blown head gasket.
Check out the video for chemical fix.
Jan 13, 2014 | 1996 Dodge Caravan
INstalled new battery on Craftsman Riding mower. Now the motor wont start or even turn over.
You may have shorted out one of the wires going into the battery, blowing a fuse, or damaging the starter or the starter solenoid.
Mar 30, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a allis chalmers lawn tractor wont start model 916H no voltage to starter?
Check the volatage at the battery, then check the voltage at both sides of the solinoid. You should have the same voltage at one side, and none at the other ( the one going to the starter/generator). The other problem could be that you have lost your ground. Try cleaning the battery terminals, and with the meter set to volts DC, touch the red to the positive terminal and the black to a known ground (engine block, tractor frame, exaust manifold) and your meter should read the same as it did across both terminals. If it is less, you need to clean the ground at both ends. If you hear a "Click" when you turn the key to the crank position, you know that the solinoid is good. Have you tried to jump the tractor with your truck or car?
Nov 07, 2010 | Garden
There is a black smoke coming of the exaust? and it is shaking too much when it is on
a bad fuel pressure regulator causes this. black soot on plugs, black smoke from tailpipe, running rough, stalling. first check plugs and wires.
Jul 01, 2010 | 1993 Oldsmobile Cutlass Supreme
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Nov 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
1.9 Litre blows black soot and wont go over 40 kilometers an hour
you probably need a new mass air flow sensor. disconnect and drive it. I had the same problem and when I disconnected the sensor it ran good.
Dec 11, 2008 | 2002 Volkswagen Jetta TDI
1993 Saturn,5 speed; engine races when no power is applied to drivetrain, stalls when pulling away from stop, RPM's drop to near stalling when A/C is activated, black soot blows from exaust, exaust system...
Have you ever changed your Engine Coolant Temperature Sensor (ECTS) ? This small (about the size of your little finger), if bad, will cause your engine to run very erratic. It is a sensor, screwed into the engine, and the other end connected to your car's computer and is not the sensor that shows your coolant temperature on the dashboard. If it is bad, it will keep "telling" the computer that your car is not warmed up, and it needs more fuel. Auto parts stores should have the sensor for less then $20. GET THE ONE WITH THE BRASS TIP. Google "saturn forums", pick "saturn fans" and all the saturn "stuff" is on that forum.
Aug 02, 2008 | 1993 Saturn SC1
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
