Question about Stihl Garden
Remove plate behind clutch does pull of unscrew ts 350 stihl disc cutter? 8
3 Suggested Answers
suzukiracing
  • 200 Answers
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: where can i get a
Try this link for the owners manual:
http://www.stihlusa.com/stihl_ownersmanuals/TS350_Manual.pdf (4.08 mb)
Let me know if it does not work for you. It worked fine for me.
Thanks for choosing FixYa, Kelly
Posted on Aug 02, 2011
How to remove clutch from Stihl fs81 brushcutter?
go google and type in --workshop manual for Stihl brush cutter model fs 81 -- and download the pdf version from the stihl site
Feb 08, 2016 | Stihl Garden
Stihl ts 400
Try some WD40. I know everybody said to do that but the throttle has some corrosion on it or rust.
Apr 23, 2014 | Hand Tools
Bt 360 stihl
possibly a fueling issue, check fuel filter, tank vent and possibly replace carb diaphrams.
Feb 25, 2014 | Stihl 08s Ts 08 350 360 Bt 360 Clutch Hub...
Apart from using the wrong mixture of 2 stroke engine oil and petrol what causes the pistons to be dameged on a ts410 stihl saw
Power cutters run in a very dusty enviroment, if concrete dust passes the filter and enters the cylinder it will very quicky remove the plating on the cylinder and wear the piston skirt, once into the bearings it will destroy them, if the rings are badly worn ( remove them from the piston and check the end gap by entering them into the cylinder, if the gap is excessive you have had dust entering the cylinder )
Mar 06, 2013 | Garden
Where can i get a manuel for a stihl ts 350 disc cutter
Aug 02, 2011 | Stihl Garden
Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
Jul 14, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
I need to change the oil pump in a stihl 026 chain saw but I am not sure how to access the pump. I believe it is beneath the armature but I am not sure how to take it off. Any advice or a...
Removing the Oil Pump
  • 1
    Pull off the spark plug's rubber boot. Unscrew the spark plug with the socket wrench. Remove the spark plug and insert the piston stop tool into the hole. Remove the starter cover and turn the flywheel by hand until the piston contacts the stop tool.
  • 2
    Unscrew the brake band's cover screws with the star Allen wrench. Remove the brake spring from its anchor pin with the end of the screwdriver. Caution: this spring is under a lot of pressure and may pop out unexpectedly. Remove the brake band from its seat on the crankshaft.
  • 3
    Remove the E-clip that holds the washer, sprocket and clutch drum to the crankcase. Pull them off the crankshaft. Unscrew the clutch's bolt with the socket wrench. Loosen the bolt clockwise and remove from the crankshaft. Pull off the washer. Remove the clutch shoes and the clutch spring.
  • 4
    Twist the worm and drive spring clockwise and remove them from the crankshaft. Unscrew the oil pump's mounting screws. Take the oil pump off its seat and remove from the crankshaft. Remove the bottom washer.
  • 5
    Disassemble the oil pump. Knock out the spring pin on the bottom with a punch. Pull the bottom control bolt from its hole and remove the O-rings. Pull the end plug off housing and remove the pump piston, spring and washer.
Read more: How to Repair the Oiler on a Stihl Chainsaw ' eHow.com http://www.ehow.com/how_6515266_repair-oiler-stihl-chainsaw.html#ixzz1H62BeTAW
Mar 19, 2011 | Stihl Chainsaw 024 026 Oil Pump
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Garden Logo
27 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
