Question about AMP Computers & Internet
Hi family its my first time here. anyway my PVi 3000 amp is producing a scratchy sound on one channel (A) to be precise. The other channel is good. what could be the problem and where to start?
I was powering my monitors 15" EV speakers all of the sudden there pops out a scratchy sound. pls help.
  • 31 Answers
SOURCE: Sherwood AI5010 no sound from either channel
Hi There DEKCAT
Its very unusual for both channels to blow......
I suspect that there is a blown power fuse inside the case......
There are fuses sometime located on the outside rear of the case and these can be easily checked to determine if they are blown..If you find one is blown please replace with the corrrect rated fuse,..... its current rating wil be on a small label on the case outside rear. like 1.0amp, or 1.5amp etc...
If you need to go inside the case please ensure the power plug is removed from the wall socket first.
You will find small glass fuses in the DC power supply feeds and probably one of these has blown, once again replace with the correct rated fuse.
Im not sure if your amplifier is a FET type or a large 32-40 pin IC type as if these are blown you will need a service person to do the replacement...
Please note there is a small relay that clicks 20seconds after turn on at the switch....if this click is not happening then there is problems with the timer circuit or the relay itself...
This relay controls the output to the speakers and as such stops all the sound output if its not working...so the first thing is to check all fuses, if they are OK then check the Relay operations....
Cheers From YUBEUT
Posted on Nov 16, 2007
petraman7
  • 1175 Answers
SOURCE: Gem Sound XP-350 both channels failed
Speaker fuses are generally fast-blow styles 250 volt glass
If an amp shuts down, with speakers connected, it sounds like one of the power supply lines does NOT like what it's "seeing" . Probably output transistors bad ( or module)
Take it to a tech.
Scott out.
Posted on Jan 08, 2008
marsrover
  • 682 Answers
SOURCE: No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Posted on Sep 30, 2008
  • 132 Answers
SOURCE: popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Posted on Feb 01, 2009
male_28_cam
  • 1555 Answers
SOURCE: Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Posted on Aug 04, 2009
Peavey PVi 4B - No sound
First, Power Supplies, regulators, condensers.
If not, and you get a POP, probably your Output Transistors (MOS ?) are pulled to one of the voltage rails. Change these.Check for shorts on them or blown ceramic resistors (square white thingies) close to them. Luck !
Mar 04, 2014 | Peavey PVi 4B 4 Channel 100-Watt Powered...
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
Lg 3000 42in tv, no picture just blank screen but sound is working
Sounds like a problem with your backlights. Could be the inverter, the CCFL's, the power supply board, or even the main board causing it.
But don't fret, this could be a very good opportunity for family bonding. I like to stand up in front of the TV and act like what should be showing on the screen for my family's viewing pleasure.
Ok, I used to do that anyway. But my family left me for some reason.
Jun 08, 2010 | LG 42LG30 42 in. LCD HDTV
I was given the amp and I want to test it with a volt meter to see if it even works. I currently dont have a system .
Easiest way, get any old speaker 4 or 8 ohm and hook it up to channel 1 then plug an rca lead into channel 1, power up amp and touch finger on rca and you should hear pop or scratchy sound from speaker . Audio circuit for channel 1 is good . repeat for channels 2 3 4 .
Mar 17, 2010 | Eclipse PA5422 Car Audio Amplifier
Sound is scratchy.
possibly update or reinstall drivers for the sound card. In "device manager" find your soundcard and update drivers( you can always roll back to former drivers if this doesn't work. Also check mfg.s website forum for said sound card for insight into the problem. Don't forget, because it's an Acer doesn't necessarily mean the sound card is by Acer. good luck.
Mar 13, 2010 | Acer (54.AA806.001) Sound Card
Scratchy intermittant noise on warm up
Hi, how old id the amp?
Have you tried re-seating the valves? Give this a try.
It could be a multitude of things, Solder Joints, Leaking / Bulging capacitors, Dried Out Capacitors, Faulty Valves.
It could be that the valve might be on there way out.
Which amp do you have?
I can't really offer anything more, but if you have more questions, then please ask.
Regards - Anthony
Feb 26, 2010 | Audio Players & Recorders
Sansui QS-100 Problem with one rear channel
There are 2 250v 4a fuses inside the amp. They can blow and
that channel will cut out. Check the fuses.
Nov 19, 2009 | Audio Players & Recorders
Re: scratchy speaker sound quality
Have you tried with headphones?  Scratchy WITH heaphones. Reinstall driver. If it's NOT scratchy with headphones.  Either your speakers are blown, (which usually doesn't happen), you need to reinstall your sound card drivers, or bad settings.  Double click sound horn. Turn some volumes haflway, or mute sound channels you aren't using. Options Properties will let you show ALL sound properties. Ctrl+S makes the sound properties half size.
ReInstall Drivers: Start - Settings - Control Panel - System - Device Manager, Expand Sound Controllers, Right Click on your sound card, Click Uninstall.  Reboot and reintall.
Might ask to reinstall automatically.  Thats fine.  Install then reboot.  I prefer to cancel the install until I have rebooted.  But both ways tend to work.
Hope you don't have to change your speakers.  Need to pull your mobo to get to em. Instructions here pg. 5-55
James Mac
Sep 08, 2008 | Compaq Computers & Internet
Sony TA-540E TWIN DRIVE AMPLIFIER
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
Mar 22, 2008 | Sony TA-FE370 2-Channel Amplifier
Computers & Internet Logo
60 people viewed this question
Top AMP Computers & Internet Experts
NOEL
NOEL
richie46
Tom Chichester
Are you an AMP Computer and Internet Expert? Answer questions, earn points and help others
