Question about Stihl Saws
How to remove plate behind clunch does pull of or unscrew ts350 stihl disc cutter
Dolfoff
  • 148 Answers
SOURCE: I have a stihl ts350 demosaw I'm not getting any fire
Follow the two wires and look for scuffs broken or worn insulation. Sometimes easy to find by turning off the garage lights and pulling the rope (arcs can be seen easier this way). The wires use common ground to kill the spark through the switch. These wires are known to wear through the insulation after years of use and they inadvertantly ground out the ignition coils. Repair the wires with heat-shrink tubing or electrical tape as needed. Or replace the wires entirely if they are in very poor condition.
Hope this is helpful,
Dolf-
Posted on Nov 11, 2009
Testimonial: "thanks for the help "
suzukiracing
  • 200 Answers
SOURCE: trying to start a stihl ts 400 disc cutter i
Try cleaning the plug and spray some starting fluid in the carb.Hope this helps and Thank You for asking!!!
Posted on Jul 19, 2010
Asbestos 56
  • 191 Answers
SOURCE: I have a stihl st400
compressed air works well. you really need a gun with a long skinny nozzle. for example
Posted on Jan 26, 2011
snor38
  • 118 Answers
SOURCE: Why won't my Stihl TS350 cuttoff saw go to full
Hi amills back the idle mixture out 1quarter turn. GOOD LUCK
Posted on Feb 25, 2011
SOURCE: how to remove stihl ts350 clutch
how to replace a TS350 stihl saw clutch
Posted on Mar 14, 2011
Husqvarna pull cord
remove the recoil housing and add an extra turn on the recoil cord on the spool to take up the slack.
Nov 27, 2013 | Stihl Saws
How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Need repair manual for stihl ts350 super
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Jul 05, 2012 | Saws
My stihl ts 760 , no gas going to carb. I have changed all filter , fuel, air, all gaskets , all gas hoses, new decompression valve, plug, cleaned carb. was working before this . Any ideas?
Clean it again you missed something or maybe a gasket is on wrong. If you went through all of that it should run fine. Stihl usually rebuilds and runs well. Slow down turbo maybe you got a little ahead of yourself. Good Luck...
Apr 02, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Why won't my Stihl TS350 Cutoff saw go to full revs? It starts well.
I would inspect the intake side of the piston behind the carburetor. The most common problem with cutoff saws with no water kit is fuel reversion. that is wear on the intake side of the piston that has removed over 10% of the machining marks like this:
If you do have wear like this consult a Stihl Gold certified dealer like www.arcolawn.com for parts and tools to repair it.
Good Luck
Dec 11, 2010 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Dolf-
Nov 10, 2009 | Garden
How to remove stihl ts350 clutch
Oct 14, 2009 | Saws
Saws Logo
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
 steve
steve
Are you a Stihl Saw Expert? Answer questions, earn points and help others
