Question about Coffee Makers & Espresso Machines
How to set opening and closing of the gate on a Hansa de lux 1?
3 Suggested Answers
  • 3 Answers
SOURCE: 1. I have an elite slide gate opener it will open
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Posted on Apr 15, 2010
  • 253 Answers
SOURCE: gate light on even when gate is closed
Open gate and find where the wiring enters the gate (bottom of door) pull back the rubber insulator and check for broken wires or wires touching each other.
Posted on Mar 05, 2013
Have a BFT Phobos BT gate opener. The problem I am having is my gate won't close all the way. There is a small gap. I tried to set the limit switch by removing the screw but it isn't...
The opener may have been mounted improperly or may have slipped from it's original mounting location. You may not be able to make an adjustment because the arm is already fully extended.
You may have to re-position the gate opener.
Fixya doesn't do repairs. Posting a question here is like calling the public library for an answer that they can look up.
Feb 02, 2015 | BFT R93524500001 - Swing Gate Kit, Single,...
User manual for Hansa speedo 1200kg sliding gate
This may help;
http://www.pruisgroup.co.za/download.php?list.34
Dec 14, 2013 | Computers & Internet
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Saeco Magic De Luxe Espresso Machine Control Panel Doesn't Work
Do you have any of the left 3 lights on the top row? If you have the one that looks like 2 arrows pointing towards each other do this
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
May 17, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe grinds but plugs up at door
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
May 10, 2009 | Saeco Vienna De Luxe Espresso Machine
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
If you take of the bean hopper and the adjustment pin, then you can turn the outer ring clockwise 4 step.
Check also that the ring not is loose.
Jul 15, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna de luxe
Try to open the steam knob to see if the pump start.
Jul 04, 2008 | Saeco Vienna De Luxe Espresso Machine
1 would be the finest. I wouldn't recommend going under 2 though.
You risk clogging your grinder and machine under 2. There's also a dosage control when you open the door on the side. + means a bigger dosage or puck.
Hope this helps.
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
