Question about Sony Computers & Internet
Suggest dvd player compatible to sony dav-dz120k home theater speakers
Ajay
petraman7
  • 1175 Answers
SOURCE: how to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Posted on Jul 07, 2008
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
SOURCE: Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Posted on Apr 28, 2009
SOURCE: hook up Sony Bravia Home Theater DAV-HDX277WC
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
Posted on May 03, 2009
SOURCE: Remote code for Sony Home Theater
This works for ALL Sony Home Theater Systems
Remote Code: 21232 (a Sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Function = 44750
Mute = 33743
Posted on Jun 25, 2009
Type your question here...
I am having SONY DAV-DZ100 DVD Home theater system. The player is reading all the MP3 format cds and If I Insert any DVD, the message showing as "can't play this disc", even its a new DVD. Please suggest the solution.
Oct 12, 2011 | Sony DAV-DZ100 System
In sony dvd model dav-dz120k when switch on the dvd set wil on and turn to protection mode
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Jul 19, 2011 | Sony Dream Home Theater System, DAV-DZ120...
Sony Home Theater System DAV-HDX277WC - I get sound and video when playing a DVD, but no voices. Tried many different movies. Any suggestions would be appreciated.
Verify that all speakers work for test tones first. The center carries most of the dialog. It's in the manual, as is your symptom (page 101).
May 21, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Sony DAV HDZ235 with Ipod nano
u would need to buy a docking station that is compatible with the sony system try ebay to get one cheap
Dec 04, 2007 | Sony HOME THEATER SYSTEM System
Is it possible to use the speaker system on a different DVD player?
I believe I understand what you're asking here. To the best of my knowledge sony puts a special type of connector on the reciever end of the speaker wire which will probably not be compatible with any other reciever brand. Depending on the age of your system, the speakers may not even be compatible with the new Sony models. Wait...there's good news though. Whatever reciever/DVD player you decide on, there will surely be speaker outputs and if you snip of the Sony connector and strip the wire a bit, you shouldn't have a problem. A couple of other things to consider though... A conventional standalone DVD player may not have outputs for five speakers and a sub. That sounds more like a dedicated reciever. I have a crazy suggestion but you might save yourself some money and trouble. -If you are satisfied with the speaker portion of your current system, buy a cheap DVD player, run the video out to the TV, the audio out to the AUX audio in on your current system and use it for sound only. Hope something in here helps.
May 29, 2007 | Sony DAV-BC150 System
Computers & Internet Logo
54 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
