Question about The Computers & Internet
My unisurf 14 notebook will not start up after being in sleep mode. Are you able to provide info on how to start up the notebook again?
Blinking light
All the time, or only when in Sleep/Hibernate mode? Is the battery charging properly? A bit more info. Shut down Sleep and Hibernate to verify.
Jul 03, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Dell inspiron 1545 goes to sleep while in use
The solutn is...please uninstall..the AHCL driver from ur pc..then the problm is solve...try it...thank u..
Mar 26, 2013 | Dell Inspiron 1545 Notebook
How to put my computer to sleep mode
I do not recommend sleep mode for windows because it eventually causes windows files to corrupt because of in proper shutdown, forcing you to do a full install of the operational system.
Mar 17, 2012 | Dell Latitude D830 Laptop Computer PC...
Turns on when it's suppose to be off
This solution is for Windows Vista, if you are using some other Operating system please let me know about it.
Option 1:
1) Go to start and type in the search box Power Options hit the enter button
2) On the Left side there is a panel Click Change when the computer sleeps
3) Click the drop-down box which says Put the computer to sleep and select Never
4) Click Save changes
Option 2 :
Try
Following solution is for vista, incase you are using some other operating system please let me know.
Look at the following pictures, there is a small arrow on the right, click the same arrow from your Start menu and select Shutdown button as shown in the picture below.
Following picture is of sleep mode.1901d1197152393-power-button-sleep_hibernate.jpg
Following picture is of shutdown mode 1900d1197152386-power-button-shutdown.jpg
Incase you have classic vista menu, please do the following.
For further reading please go through the following link.
http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html
http://www.vistax64.com/tutorials/68146-power-button.html
This solution is absolutely free.
Please rate. If not resolved, please post a comment and let me know, so that I can research and provide you with a better solution. Thanks :)
May 02, 2010 | Dell Inspiron 1525 Notebook
My computer does not go to sleep mode
Start > Put computer to sleep
This should work.
Aug 09, 2009 | IBM ThinkPad A21m 2628 Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
I can not start laptop because it stays in sleep mode.
Do A "Cold" Boot...
Remove The Battery For 30 minutes, And Leave It Unplugged..
With No Battery in and No Charger Cord Plugged In Now, Press and Hold the Power Button Down For 30 Seconds.....
After 30 minutes, Replace Battery and AC Adapter and Attemt to power on "hopefully not in sleep mode"
Nov 20, 2008 | IBM ThinkPad R31 2656 Notebook
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Sleep problem
I've seen this on many Dell machines, and I've found no real fix for this. It seems that this function either works or it doesn't. You can do a restore back to a point that you remember it working properly, but eventually it will start doing it again. I've decided that this is a glitch with Dell's systems. You can also do a bios update from Dell's support site, sometimes this helps with the little glitch they pick up.
Jul 01, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
212 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
