Question about LG Washing Machines
Getting a d3 error message when trying to wash
LG top load fuzzy turbo drum. Washed okay till next load was added, it starts to wash then comes up with d3 flashing error code
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
Dissolu
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
SOURCE: Error code
My Whirlpool Duet Steam washing machine used to run for a couple of minutes, then it would say SUDS on the display, and then it would display error code F35. To fix this, I removed and replaced the analog pressure switch located under the top cover panel in the back right corner of the washer (as viewed when standing in front of the washer looking down at the top). I called the Whirlpool customer service 1-800 number that I found in my washer's instruction manual to order the switch. The part number of the switch is: W10156252. The model number of my Whirlpool Duet Steam washer is: WFW9600TW01. I paid a total of $89 for the switch and overnight FedEx shipping.
What I learned in the process:
1. The "Analog Steam", and "Analog Pressure", switches that everyone speaks of are the same thing (at least according to the customer service representative with whom I spoke).
2. I read somewhere that you can determine if the switch is broken by blowing into it and listening for a click. Allegedly, if no sound can be heard the switch is broken. This is not true!! The broken switch on my washer did not make a sound when I blew into it, but neither did the new switch that I received from Whirlpool (which ended up fixing the washer).
3. The customer service representatives will barter on the price of the switch!
Hope this post helps you remove and replace your bad Analog Pressure switch. I tried to upload a labeled photograph of the washer and switch but this site would not cooperate.
Read more: http://forum.appliancepartspros.com/washer-repair/35193-f-35-trouble-code.html#ixzz0ywbfWNsG
Posted on Sep 08, 2010
tinusdebruyn
SOURCE: My washing machine LG Turbo
My LG has a magnet on the lip of the door flap. This magnet sits behind a flimsy little plastic clip that is bound to break off after a while. Look for the magnet inside your drum - it will stick to the walls of the drum. Stick it back on with masking tape or glue. Simple cure for a sloppy design!
Posted on Jan 29, 2013
Have a 7.5 Kg Fuzzy Logic top Loader that does not spin
Hello.. DE Error means door error but if wash cycle is working properly means you need to change your drain motor.
Feb 13, 2018 | LG Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Ii have a LG WFT9250PP Fuzzy Logic top loader washing machine. I keep getting dirty ****-like marks on my washing.
Run a hot wash with a Descaler which is available form most hardware stores.Marks on washing usually comes from a build up of detergent and softner between drums.
Oct 15, 2011 | LG WFT1071TP Top Load Washer
My fuzzy logic turbo drum WF-t1340tp machine is getting a de error message. The machine start quite alright, and start to move but only for a while, then it shows the de error message. What is the...
Door Error. Could be that the lid gets bumped open while washing. Make sure it is secure, or it could be a loose connection on the wiring of the door switch itself. This feature is used to prevent small children from sticking their hands into the machine while it is operating, it switches of the working components as soon as an interruption is made with the Door switch.
Hope this helps.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | LG Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
