Question about Cell Phones
How to enter my pin to start - Cell Phones
My harley wont start
Key fob MUST be present near bike!
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
TO ENTER NEW PIN:
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
Aug 10, 2014 | 2011 Harley Davidson FLSTC Heritage...
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
I forgot my phone lock code and pin code,help me break it
Enter wrong pin code then it will ask for puk code.Then call ur sevice provider from some other phone and tell them ur phone number they will give u ur puk code. Enter it ur phone starts. Now open settings->security->lock code
Go to folowing site enter ur imie and get ur lock code and enter the new one..
www.nokialockcode.com
Aug 12, 2009 | Lands Phones
I've tired to set the PIN code for my Nokia 6085 phone but I cannot. I've entered the PUK code but now it says, "Enter new PIN code:" What do I do? I've entered a code I wanted and other ones on my...
HOLD ON!
You may enter wrong PIN three (3) times only. After that your PIN will be blocked! To unblock, you need PUK. You can only enter wrong PUK ten (10) times. (This is as documented) After entering correct PUK, you will be asked for NEW PIN.
So, when it says "PIN blocked. Enter PUK code", you must enter the PUK. If you correctly enter the PUK, it will asked for new PIN, by asking "Enter new PIN code:". Enter anything you want as your PIN. You will be asked to enter it twice (two times).
From what I read from your post, you have done correctly, but you don't want to enter new PIN. There is no way SIM card/phone will use old PIN. The device doesn't know your PIN. So, you have to enter new PIN.
Dec 25, 2008 | Cell Phones
Puk disabled
if you enter the wrong pin code for 3 times your sim will get blocked ...
it will ask for the puk code ...
then you must call to the customer care of your network provider from some of your friend s cell of same network connection and you must tell them that your pin got blocked you want the puk code ...
they may ask for the details of your sim card be sure to tell it ..
then they will provide the puk code note it down and enter into it ..
your sim will get unlocked...
note :
if you enter the wrong puk code for more than 3 or 10 times the sim will get fully blocked if then you must contact to network provider shoppe....
any doubts reply me
i am always here to assist you
thank you
bye
Apr 11, 2008 | Nokia N73 Cellular Phone
Pin blocked
Complete information :
The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
  • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
  • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
  1. When PIN Blocked appears enter your PUK > OK
  2. Enter a new four to eight PIN > OK
  3. Re-enter the new PIN to confirm > OK
To edit your PIN:
  1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
  2. Enter your PIN > OK
  3. Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
  1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
Apr 06, 2008 | Nokia N73 Cellular Phone
hi
as youve entered the puk code, it asks for the new pin code, the default code was 1234 right? so if you are going to try the new pin code yu can either invent a new pin code or just enter the default code.
hope this helps.
Jan 24, 2008 | Nokia N73 Cellular Phone
How many times i can enter wrong pin
Uh...good luck. You do know there are MILLIONS of different combinations that it could be, right? There is no limitation to how many TIMES you can try entering the PIN as far as I know, but you can only enter an incorrect PIN once before the unit locks. You can unplug it and try again in a few minutes, but your best bet is to return it to Garmin. You will tire of this long before you guess the correct PIN number.
Jan 22, 2008 | Garmin StreetPilot c550 GPS Receiver
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
