Question about LG Computers & Internet
LG E310 Laptop,WD Scorpio Blue MDL:WD1600BEVT-22ZCT0 connection looks like Sata but it is not the usual structure To get it out you a have to lift it and to insert it back you place from the top down
Sata that I familiar with you slid it sideways to connect it to the laptop Any one femiliar with this model
SOURCE: WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at Good luck cloning
Posted on Jun 01, 2009
SOURCE: eSATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
Posted on Jul 26, 2009
  • 210 Answers
Have you try to right click the hard drive and click explore. more likely this will openif you can see the icon. the other way to access the external internal hard drive click start, click control panel, click administrator tools, click computer management, on the left hand side click disk management. All hard drive will show or appear and you can format, rename and do partition, the hard drive that you having a problem to open. You may choose primary or not to format. I hope this will help you to solve the problem.
Posted on Aug 12, 2009
SOURCE: Lenovo 3000 N200 Not recognize my WD Scorpio 160Gb HDD sata
When a hard drive is not recognized in the BIOS then it indicates a hardware malfunctioning. In this case, service is required.
Posted on Sep 15, 2009
  • 366 Answers
Sounds liek your hard drive has failed, search ebay for this model of laptop with hardrive at end of yoru search, not 100 percent sure but im nearly 90 percent sure its hard drive failure.
Posted on Dec 03, 2009
How to fix my wd scorpio and can use it again?
Open Control Panel ' select System ' select system devices ' look for yellow triangle on unknown device or under storage device / hard drives. Select detect / add new device with drive connected.
Feb 12, 2015 | Western Digital WD Scorpio Blue WD2500BEVT...
The machine you're trying to use the disk in, is there another disk installed?
Lost password on WD Scorpio Blue WD5000BEVT hdd
Password is for the computer, not the hard drive. Get a Linux LiveCD and reformat the drive.
May 05, 2014 | Western Digital WD Scorpio Blue WD1600BEVS...
Looking for a connector for wd scorpio blue WD6400BPVT to move data to jump drive
These kind of "docks" can be found on ebay for drive diagnostics or file transfers without opening your computer.
Feb 09, 2014 | Western Digital Scorpio Blue WD6400BPVT -...
WD1600BEVS Scorpio pin settings
You shouldn't have any problems. The computer uses SATA drives and the drive is SATA and is also a 2.5" laptop HDD. Make sure that you have a way to install an OS , etc
Nov 13, 2013 | Western Digital WD Scorpio Blue WD1600BEVS...
Please visit your nearest Service or care center for best result.
Do not perform R & D at your own level.
Thanks & Regards,
Rakesh Kumar
Oct 18, 2013 | Western Digital WD1600BEVT-00ZCT0 Scorpio...
Format wd scorpio blue wd250bevt
Jul 06, 2013 | Western Digital WD Scorpio Blue WD2500BEVT...
Wd scorpio blue 160 gb how to reset
Reset it or format it ? cause there is no reset for hard disks.
Is your hard disk operational ?
Jul 29, 2011 | Western Digital WD Scorpio Blue WD1600BEVS...
My hdd wd scorpio doesn't read in my Laptop, how can I fix it?
This guy does remote data recovery he may be able to help you.
May 19, 2011 | Western Digital WD Scorpio Blue WD5000BEVT...
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
