Question about Tablets & eReaders
My digliland tablet will not turn on Evan when I hit the reset button
How do I reset this tablet
Since model number you wrote is for kickstand I assume that you want to reset Galaxy tab 3
Please make sure you have backed up all of your important data and apps before performing a reset.
Turn your Galaxy Tab 3 off.
Press and hold the Volume Up, Power and Home buttons together until you see an Android lying on its back. This is the - stock recovery screen.
Use the volume keys to scroll down to Wipe Data/Factory Reset and use the Power button to confirm.
Scroll down to Yes, Delete All User Data and hit Power to confirm.
Back on the first screen, scroll down to Wipe Cache Partition and select with power button.
Hit Reboot System Now to restart your Galaxy Tab 3 with factory settings restored.
Oct 15, 2016 | Tablets & eReaders
My tablet is stuck in factory reset mode
you will need to do a factory reset by pressing the power button and volume button at the same time holding both until it shows the screen. turn tablet off turn on hit buttons.
Feb 27, 2016 | Tablets & eReaders
How to reinstall os operating system on a proscan tablet
First Turn off the Tablet, and locate the small pin hole reset.
Press and Hold the Power button while poking the hidden reset button with a small object like a paper clip until you see the Android logo, let off the power button.
Use the paper clip and poke the hole to navigate the menu, hit the power button to accept the menu items.
First select Wipe Data if available, then Select Factory Data Reset. Reboot the tablet after it is done reinstalling Android.
This is a common problem with these off name tablets, be weary when buying cheap devices.
Oct 11, 2014 | Tablets & eReaders
I have a proscan tablet plt7777g. It will not load it turns on and gets to part where it says android but it just stays there.
First select Wipe Data if avialable, then Select Factory Data Reset. Reboot the tablet after it is done reinstalling Android.
I hit the reset button on my Visual land connect 9 internet tablet and now it won't turn on at all!
I think you need some diagnostic tool check your car problem, giving http://www.xcardiag.com/ for your reference , hope it can help you .
Mar 19, 2014 | Visual Land Connect 9" Android Tablet...
How to unlock rca tablet
1. Turn your tablet off.
2. Hold volume up and power button at the same time.
3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
Mar 01, 2014 | Tablets & eReaders
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Oct 16, 2011 | Archos ARNOVA 10 Android Tablet
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
71 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
