Question about Cell Phones
I have a problem with fixing my tap - Cell Phones
Sound not working on my tablet
hi Claire.
How do you fix the volume on your tablet? To verify the volume when audio or video are not playing:
  1. From the home screen, tap All Apps.
  2. Scroll to and tap Settings.
  3. Tap the DEVICE tab.
  4. Tap Sounds and notifications.
  5. Tap and drag the Media slider to the preferred volume.
Troubleshoot audio playback issues on your Samsung Galaxy Tab 4
https://support.sprint.com/.../WTroubleshootingGuide_542_GKB76043-dvc8270006prd Search for: How do you fix the volume on your tablet?
you could try this link as well.
no sound on tablet
or this one.
Sound not working on my tablet Google Search
Nov 27, 2017 | Tablets & eReaders
Tip
Fix "Cannot connect to YouTube" problem from iPhone/iPodTouch
Fix the following problems:
  • iPhone / iPod Touch cannot connect to YouTube
  • FaceTime Activation
  • Push Notification
  • GPS location / signal & others
These problems were caused by hactivating your iDevice.11e8ffe.pngRequirements:11e8ffe.pngJailbroken iDevice with Cydia WiFi connection11e8ffe.png Works for the following iDevices:
  • iPad
  • iPhone 4
  • iPhone 3GS
  • iPhone 3G; or older
  • iPod touch 4th generation
  • iPod touch 3rd generation
  • iPod touch 2nd generation; or older
Supports all iOS versions up to iOS 5.0.11e8ffe.pngProcedures:
  2. In Cydia's homepage, look for More Package Sources and tap on it.11e8ffe.pngRepositories are like databases for apps, you will find more apps on Cydia adding a certain repo (repository). Just take note of the warning on top of the "More Sources" page before installing all other repos11e8ffe.png
  4. Tap on Manage (from bottom tabs) then tap Sources on the middle11e8ffe.png
  5. Look for iPhoneModding (on Sources list this time) and tap on it11e8ffe.png
  6. Look for Push Fix and tap on it.11e8ffe.pngTo make your search easier, tap on the letter "P" on the right side of your iDevice's window to take you directly to the apps / themes starting with "P".11e8ffe.png
  8. Reboot your iDevice. After the reboot, YouTube should work perfectly.
And you're all done!
11e8ffe.pngOther tips: iOS 4.2.1 JAILBREAK http://www.fixya.com/support/r8764632-jailbreak_ios_4_2_1_all_idevices_iphone iOS 4.1 JAILBREAK http://www.fixya.com/support/r6356589-jailbreak_ios_4_1_iphone_4_3gs_ipod iOS4.0.1 JAILBREAK http://www.fixya.com/support/r5452955-jailbreak_all_idevices_iphone_4_3gs UNLOCK http://www.fixya.com/support/r5537989-unlock_iphone_4_3gs_3g_or_older_ios Credits: kidantvideos Cydia by Saurik iPhoneModding Push Fix by Darks
on Feb 07, 2010 | Apple iPhone 3G
Can't open send or receive email on iPhone 6
Method 1: Verify email account settings on the Mail app.
  1. Go to Settings.
  2. Tap Mail, Contacts, Calendars.
  3. Tap the email account.
  4. If necessary, tap on the account again.
  5. Scroll down to the bottom of the screen.
  6. Under Outgoing Mail Server, tap the right-arrow (>) next to SMTP server information (hostname).
More items...
How to Fix Apple iPhone 6 that can't send emails using POP/IMAP and ...
www.ikream.com/.../fix-apple-iphone-6-cant-send-emails-using-popimap-exchange-acc...
Nov 26, 2016 | Cell Phones
How do I fix a leaking tap
house tap
shut of the mains water supply
remove the insert of the tap
pull out the old washer
( professionals will reset the tap seathere)
fit a new washer
assemble the tap
turn on the mains water
if that is beyond your experience , call a plumber
Oct 08, 2016 | Cars & Trucks
When you Galaxy Samsung Say Not registered on network when you trying to call someone How to fix that
According to WikiNix.com:
Step 1:
First, go to Settings.
Step 2:
Then go to Wireless and networks.
Step 3:
Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks). Watch video to understand and solve this issue easily.
Step 4:
Now tap Networks operators.
Step 5:
After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Updated Fix 1. In Mobile Networks, set Network mode as WCDMA only and restart your phone. After restarting, follow above steps. That.s it (Updated on 12 September 2014). "
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
May 10, 2015 | Samsung Cell Phones
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
How fix lycamobile internet in Samsung Mobile Phone galaxy s 3
hears try this one
Setting up my mobile phone for internet
Want to set up your mobile phone for internet? Follow these easy instructions.
1. Find "Access Point Names"
Tap Apps.
Tap Settings.
Tap More settings.
Tap Mobile networks.
Tap Access Point Names.
2. Create new data connection
Tap the Menu key.
Tap New APN.
3. Enter data connection name
Tap Name.
Key in Optus Yes Internet and tap OK.
4. Enter APN
Tap APN.
Key in yesinternet and tap OK.
An APN (Access Point Name) is used to establish a data connection.
5. Enter country code
Tap MCC.
Key in 505 and tap OK.
6. Enter network code
Tap MNC.
Key in 02 and tap OK.
7. Select authentication type
Tap Authentication type.
Tap PAP.
8. Select APN type
Tap APN type.
Key in default and tap OK.
9. Save and activate data connection
Tap the Menu key.
Tap Save.
Tap the field next to Optus Yes Internet to fill in the field.
10. Exit
Tap the Home key to return to standby mode.
gooluck ^_^
Jul 04, 2014 | Cell Phones
Leaking kitchen tap
It is very easy to stop it just make sure you lock the tap and loose the tap head from the pipe then you get what they call white thread for taps just rap the thread round the tap and you just fix it back
Feb 05, 2014 | Home
Air lock in hot water tap in kitchen. tap was left running, how do we fix?
connect a hose from the cold tap to the hot and turn on hot tap then turn on cold tap slowly and watch for air bubbles in hot tank header if you have one, but 30 seconds should be enough. turn both taps off then try hot tap for flow, it should have cleared the air lock. You have not stated what type of system you have or if it is a pressurised system. my fix is for the old type copper cylinder and header tank system and not for a pressurised system that are mains pressure fed..
Nov 26, 2013 | JumpUSA Dribble Specs No Look Basketball...
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
