Question about Sharp Office Equipment & Supplies
Sharp ar5316 will not load paper from feeder tray or something it grabs it but does not go round the rollers for printing... any idea what the issue is..
Tried using both the bottom feeder as well as side feeder to check and both have the same issue the roller will not push the paper through
    New Friend:
    Problem Solver:
  • 7 Answers
I think youre problem is youre clouth casset paper
you have to open back cover
2- close dricer
3- close cloth
4- service cloth
Posted on May 15, 2017
Manual feed tray bypass
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Jul 25, 2012 | HP LaserJet 4250n Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Feeder won't work~~
Hello Sir; I believe just replace paper pick up roller feed roller and stop roller, the problem will be gone!
Jan 27, 2009 | Sharp AL-1551CS Copier
Dell Laser MPF 1600n WON'T PRINT
Two causes:
1. Worn out roller
<or>
2. Spring-loaded tray not engaging when placed into printer
1. The roller will try to "grab" the paper when the job starts. If it becomes too worn, it will slip and not grab anything. One fix is to apply a small amount of moisture to the u-shaped rubber roller.
Other option is to wrap a rubber band around it if you can.
2. Check to see if tray spring works properly. There is a small white knob on left side of tray. Push paper in tray down all the way until it clicks. Engage knob on side and paper should spring upwards. If this does not happen, the roller will not be able to engage the paper and it will simply click as it tries in vain.
Dec 07, 2007 | Dell 1600n All-In-One Laser Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Canon Pixma Paper feed not feeding!!
Either the pickup roller needs to be replaced,(a maintenance kit) or the tray isn't pushing the paper high enough to grab. Tyr loading a few more pages in the tray and making sure the tray is seated properly. Then try replacing the roller.
Sep 17, 2007 | Canon PIXMA MP830 All-In-One InkJet...
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
