Question about Canon Office Equipment & Supplies
I have machine of canon ir3300 this time show this problem in machine E0000007-0000 i change the film and i remove waste toner also but the code is comming E000007-0000 what is the problem
    Top Expert:
  • Canon Master
  • 25,352 Answers
Posted on Apr 21, 2017
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
I have one canon ir 2020 i copier machine how to all copies recovery at a time please infor me
To recover prints at time of failure is not possible, the device will need powering down to resolve issues such as error codes. E007 will need film replacement or clear code. E019 is waste toner need emptying, E010 is main drive motor maybe related to drum seizing from waste toner being full etc. image quality may be either film or drum. The drum Would look more streaky looking ==== could be bold and dark but will have straight lines within. and the film would be more blotchy/patchy/speckle y :;'";:;':':;;;':;';,. Please give more information if answers still not helping and whats been resolved so far
Aug 01, 2013 | Canon Office Equipment & Supplies
Error
Error code E000019-0000 is a waste toner full error, so to get rid of this error you remove the waste toner bottle which is located left rear side of the machine and dispose the waste toner and dont forget to clean the neck of the bottle because the waste toner might obstract the toner sensor passege and then switch off then on and you are up and runin.
May 12, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
Error code 0001900 for ir3300
The error code means the waste toner bottle is full. It may not be full, but once the waste toner bottle neck is dirty and the copier thinks it is full. It's a poor design from Canon. The waste toner is on the left rear side of the copier. It is behind a panel with one screw that holds it in. Remove the cover and remove the waste toner bottle and carefilly empity out the waste toner into a plastic bag. Make sure you clean the neck of the bottle. There are 2 windows on the neck. That is where it gets dirty. Return the bottle back into the copier & return the cover, Then turn the main power switch on the right side and turn it back ON and thats it... Good Luck
May 01, 2010 | Canon imageRUNNER 2200
Error code E000007-0000
I have machine of canon ir3300 this time show this problem in machine E0000007-0000.
Jan 12, 2010 | Canon imageRUNNER 3035 Black and White...
Error code: E000019-0000
Oct 17, 2007 | Canon (6981A002AA) for imagerunner 2200,...
70 people viewed this question
old marine
old marine
