Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Manitowoc Self contained watercolled ice maker Model QD0603W
Machine makes ice only at the 2/3 of the evaporator from bottom to top.
I feel the top part of the evaporator pipe from the side is not as cold as the bottom. When is shut down from circuit breaker for a few minutes it works for an hour or so then the same. Technician said pressures are okay.
This happens after harvesting seems a hot gas still going in the evaporator at the top, how is this possible.
Any help appreciated before having to buy a new machine.
Thanks Philip
  • 286 Answers
Hot gas valve needs to be seated to make sure it doesnt leak thru. At times the valve will close but it doesnt seal so it bleeds thru. You will need a hotgas valve replaced.
Posted on Jul 24, 2009
AFTER RESET IT WORKS ABOUT AN HOUR THEN STOPS
WHEN I OPEN THE COVER I SEE HARVEST RED LIGHT IS BLINKING
SOMETIMES I REALIZED WITHOUT DROPING THE ICE I STARTS ALL OVER AGAIN THAN I GET VERY THICK ICE
Posted on Feb 17, 2010
I HAVE A MANITOWOC QM30A ICE MACHINE. WILL THE LIQUID LINE THERMISTOR CAUSE IT TO RUN BUT NOT MAKE ICE?
Liquid line sensor on ice machines in general is used in conjunction with the control boards to determine defrost and harvest cycles. You could measure the line temp and chech the resistance of the sensor to check it.
Betabass
Sep 07, 2016 | Manitowoc QM30A Self Contained 65Lb...
Hoshizaki km151bah ice machine not making cubes. ice is coming out in one big sheet. Why?
The depth setting on the evaporator cube setting may be set too thick making the cubes stick together. Adjust it to make smaller cubes.
Feb 28, 2015 | Hoshizaki KM-151BAH 121 Pound...
Manitowoc QY0214A starts up and in about 1 min. goes into heating cycle. What's my problem
The ice thickness probe is a plastic and metal piece hanging from the water distribution area at the top of the ice making plate. It is probably touching or really close to touching the plate. It should be about 1'4" - 5/16" from the plate. It is adjusted by turning the screw located on the top of the sensor facing out at you. turn it clockwise to thicken the ice. the ice should come off in one large piece linked together by a roughly 1/4" sheet across the front. You can get a 1/4" drill bit and lay it on the plate behind the metal tip of the sensing probe and use it as a feeler gauge. Turn the screw until the probe just makes contact with the bit. Remove the bit and try again.
Sep 17, 2014 | Manitowoc QY-0214A Self Contained Ice...
Make ice thenfull shuts off anddoes not come on ice starts melting
The bin thermostat or door switch is sticking. If it is an adjustable thermostat turn it clockwise a quarter turn.
Jun 24, 2014 | Manitowoc QY-0214A Self Contained Ice...
Starts into ice making then dumps ice slurry in tray
Adjust the ice thickness sensor out 1/4 turn at a time until 3mm ice bridge forms between cubes. Clean condenser thoroughly, descale ansd sanitise waterways inside.
Jan 30, 2014 | Manitowoc QY-0214A Self Contained Ice...
Manitowoc ice machine freezes
most likely you have bad ice thickness probe.
Aug 31, 2013 | Manitowoc 450 Lb Ice Cube Machine Self...
It will not stay in harvest cycle long enough to make ice before it goes into defrost
First it has to go through freeze cycle then harvest cycle to drop ice then back to freeze cycle. If you have never worked on ice machines before you should call a service company.
Aug 16, 2013 | Manitowoc QY-0214A Self Contained Ice...
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
310 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
