Question about Hitachi Performa CP-RS55 Multimedia Projector
CLEAN FILTER/SET FILTER TIMER
WHEN THE LCD IS SWITCHED ON IT WRITES CLEAN FILTER AND SET FILTER TIMER. TWO RED LIGHTS KEEP BLINKING ON THE PROJECTOR.
ITS HOLDING UP MY LECTURES. HELP NEEDED URJENTLY.
FIIFI DUKU WOODE
donnatty2002@yahoo.com
  • 1 more comment
  • jaybkk Nov 28, 2007
    i have exactly the same problem. it is impossible to reset the filter timer.
  • Rakesh 50365 Feb 09, 2008
    I have a problem,my Hitachi CP/RS 55 shows clean filter immediately after starting I cleaned it but it still would pop up,my electronic service centre tried to solve and gave up have now told me to replace the mother board.Is there an alternative before I buy the expensive board? I have hardly used it for less than 2 years.
  • smallville19 Apr 28, 2008
    i have changed the lamp and air filter, reset the lamp and filter timers. but i have a lamp and temp light flashing on the top of the unit. the picture is perfect but dont know how to stop these from flashing red, can anyone help?
Go to menu, than select filter timer. press reset for 3 seconds, reset the filter timer.
Posted on Nov 28, 2007
Blinking red clock nikon camera
You need to set the date and time. See page 47 in the reference section of the manual: http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L810RM_CH(11)03.pdf
Sep 14, 2013 | Cameras
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Lights go on and off not adhering to timer schedule
You posted under Leviton 6124 timer.
I have tested this timer.
If timer worked correctly before and then started blinking, the timer might be bad.
Turn off power to timer and see if timer resets.
If this is new installation and lights are blinking on-off, then white and red wires are probably connected together.
Re-connect wires.
Open link below to read ez-wiring steps, and to access on-line manual.
http://waterheatertimer.org/Leviton-timers.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Leviton 6124H 24 Hour LCD Programmable...
My sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Apr 26, 2010 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Red light
thats not a bad thing, just clean air filter. if you have done it, then go to air filter on the menu, then keep reset pressed down - then it should be not blinking.
sorry for bad english!
Aug 01, 2009 | Hitachi CP-X275 Multimedia Projector
We have a problem similar to timmiby
Hi, replace the lamp, be sure to follow directions carefully as that set is known for door switch issues, gl, video-tek
Jun 09, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony Wega KDFE55A20 screen and sound going out, red blinking lights, but comes back on...then repeats. Replaced the bulb about 8 months ago and seemed to solve the problem. But it is occuring way too often...
p# 19100239 6 blinks indicates fuse. Do not plug set into switched outlet. besure set is allowed to cool down before ac power is ever removed. Thermal fuse is on the optical block under the lamp housing. do goole search for part availability and source.
Apr 25, 2009 | Sony KDF-E55A20 55 in. LCD Television
Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Dec 18, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Blinking red timer light
The blinking red timer means that the date isn't set on your camera. Go to the set up screen and set the date. I'm not sure why you wouldn't be able to take pictures, though...
Dec 25, 2007 | Nikon Coolpix 5200 Digital Camera
Hitachi Performa CP-RS55 Multimedia Projector Logo
771 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
