Question about Electrical Supplies
Which one is better? Rectangular Skylight or Tubular Skylight?
    Top Expert:
  • 24,732 Answers
Whatever floats your boat.
Posted on Apr 21, 2017
Sunroof quit working
Skylight itself damage, BCM control unit fault, the line problem, sunroof motor does not work and so on all may cause skylight switch failure.
auto diagnostic tool.
Apr 12, 2013 | Honda Cars & Trucks
The moonroof on my 98 nissan altima doesn't work
Apr 04, 2013 | Cars & Trucks
My skylight drain is leaking into the car
yes it's either broken or plugged with the skylight retracted look for the drain hose if not look toward the rear of the opening there is probably two drain hoses
Aug 27, 2012 | 2004 Chrysler Pacifica
How do you replace skylights?
The steps to replace would be :-
  1. Look over the roof area where the current skylight is located. Will it withstand the replacement of the skylight or is the roof in bad shape as well? Assuming all is well with the roof, continue to 2.
  2. Take measurements of the old skylight footing while you are on the roof. View information on the different types of skylights including size specifications. If you do not have to deal with a change in size, this will be a much easier job.
  3. Choose the type and size of skylight you want to buy. There are factory built and site built units. Factory built skylights are the way you want to go. Factory built skylights will seal to your roof better and offer more protection from severe weather. Purchase it from a website or store.
  4. Remove the old skylight by pulling back the roofing area where the current skylight is set. Use a prybar. Remove any mounting brackets present and take off the skylight. This will expose the hole for the new skylight.
  5. Observe existing roof or attic shafts. These are for the new skylight.
  6. Attach new mounting hardware and insert the new skylight. Make certain you read through the manufacturer's instructions, particularly where it pertains to flashing requirements. Installation instructions will vary widely, depending on the style and brand of skylight you selected. Caulk around the entire base of the skylight. Make sure you have not disturbed anything on the roof (such as shingles) that needs your immediate attention.
  7. Insure that there are no problems where the skylight comes inside the house. Take care of any problems with the ceiling view at this time. Check for leaks and loose connections. Assuming all is well, enjoy your new skylight!
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 13, 2009 | Sky Toys
I would like to know what these do
Bower is brand name skylight is slightly yellow helps soften light there are diffrent densitys. Filter is mostly used to protect orginal glass of lens from dirt smudges scratches & rough treatment. Keep on lens most of the time.
Hyda brand name. PL 3 i believe to be a dark polarizing filter.
Quantaray 1A4 I believe is a haze or skylight filter.
Haze filter does almost the same as a skylight filter.
Hanimex brand name. Polarizing filter used to shoot through reflective glass or surfaces (water), also in color used to sharpen colors. The reason it is turnable is it is light directional beaning light comes through it at a angal hold up to light & turn it you can see how it darkens or litens. Also can stay on lens when not useing skylight filter.
reason you have 2 is one of each for two diffrent lens, 49mm & 55mm.
Hope this helped. Please rate.Thank You.
Mar 11, 2009 | Pentax K1000 35mm SLR Camera
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
