Anyone know how any thing about water breaking and labor? If so got couple questions
Isnt extracting water on spin cycle
If the water in the tub just stays in the tub no matter what,then the water pump is most likely bad.If not ,there is a piece of clothing in the pump,witch has stopped the pump.Check the drain hose also,to make sure that the hose is not restricted with anything,or the hose is not crimped.I hope this answers you question,and if so,please let us know ,thank you.
Nov 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer fills with water but does agitate or spin it does pump the water out but does not spin
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions, or require additional assistance, please let me know. I hope this has been helpful to you.
Aug 19, 2009 | Washing Machines
Engine light on
It means your O2 sensor bank 1, wich is the 1st sensor on your converter, or exhuast, this will cause your problems your describing. The part probally isnt cheap but the labor and all at 500 is robery, a couple hundred at the most. I would ask someone you know that work on cars and see what they would charge. I do it all the time for people. Saves money on the labor side. I found the sensor online for 130, there ripping you off when they say 500
Jun 18, 2009 | 2003 Mitsubishi Lancer
Series 70 kenmore washer ,spin cycle not working
If the washer will fill and drain, but won't agitate or spin, you, indeed, may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
May 27, 2009 | Kenmore 15864/15862 Top Load Washer
No agitation or spin, but water pumps out.
May 22, 2009 | Washing Machines
Makes loud noise and doesn't spin does agitate and pump water out
Your washer more than likely has a broken motor coupling. This is a common fail item with this model washer thorugh normal wear and tear. Newer versions of the coupler are more resilient and resists breaking. The following link explains how to replace one:
May 12, 2009 | Kenmore Washing Machines
My water pump on my caravan is going out
I checked a couple of sites and they all listed between 3-3.8 hours labor. Depending on the market you are in labor is generally + or - $65 an hour. The water pump should run around $70 (guesstimate). In all honesty I would have the belts checked and replaced if needed at the same time. Most places will charge you very little if any additional labor because they have to take them off anyway. The belts should not be all that expensive and if possible buy them yourself ahead of time. I hope this helps
Feb 15, 2009 | 2005 Dodge Caravan
When should you change a timing belt for a 1999 magna advance?
Call the dealer or get a Haynes service manual (about $20US) for the vehicle.  DO NOT use what anyone on this or any other forum tells you as gospel, since many Mitsubishi engines are interference in design (read: when the belt or chain breaks, valves and/or pistons can be severly damaged).
Belts have a mileage rating, and whil I haven't seen a strictly set number of years they will last,  they are synthetic rubber and will over a long period of time (say a decade) get brittle even if the car is only drive to the store on sundays.  Chains last much longer.  Belt intervals go from 50K miles to 100K miles in the states
When you do the belt,replace the tensioner and any rollers in the path as well as the water pump and possibly the crank and can front seals.   The parts are cheap compared to the labor.  A $20 timing roller or tensioner gone bad, can cause a couple thousand dollars damage when it cause the belt to break !
Nov 01, 2008 | Mitsubishi Passenger Cars & Trucks
Washing Machines Logo
Top Washing Machines Experts
