Unblocking drains - Washing Machines
Hotpoint ffa71
you can dampen a small part of folded to 1/2" wide paper towel, and wrap the dampened paper towel around the end of a straw, stick that in the drain hole and blow.
Apr 30, 2013 | Refrigerators
Blocked drain pump
get a air compressor at the drain end and blow air up the hose to try unblock what ever could be over the sensor. OR get your garden hose and force water the other way to try unblock
Jan 05, 2013 | Tricity Bendix Washing Machines
We have a basement bathroom. The bath drains away very slowly, but everything else seems fine - toilet and sink draining/flushing fine. Can we use a usual unblocker (eg sodium hydorchloride) to unblock?
I worked on a lot of Saniflo products, they do not recommend using any products that have bleach or chlorine. Make sure the flapper inside the side inlet where the bath drains, is not obstructed.
Dec 03, 2012 | Saniflo & Saniplus& Macerator Pump
How do you unblock drain hose?
Couple ways to unblock a drain hose. The easiest is probably to remove the lower panel which would give you access to the drain pump. You woulld then remove the exit drain hose leaveing the pump slowly while haveing a pan under the pump and a wetvac to **** up the water so it doesnt pour all over your floor. you would then disconnect the other drain line going to the pump and also remove the line from the exit port of the tub. Also assure that the pumps impellar is spining as well. Message me back if you have any further questions. Thank you
Rick
Dec 01, 2011 | LG WM2496H Front Load
1994 xj6 has a blocked drain in the fuel filler cavity area. I can run a wire coat hanger down the drain - but I feel resistance after about 18" of the coat hanger has been inserted and can't break...
You are using too thick of a wire with a coat hanger. I use machinists wire to unblock the drain hole. The tube emerges under the car by the left rear wheel. This is a common problem and leads to water in the tank if not cleared on a regular basis.
Dec 26, 2010 | 1993 Jaguar XJ6
Does no drain
This could be a easy problem, check your drain hose is not kinked or blocked. put your mouth on out let of drain hose and blow hard if you can not blow stick something up to unblock if it unblocks from blowing great hope this helped
Jun 02, 2010 | Washing Machines
Slow drain in the bathtub, cannot use a snake because the drain hole has an old metal piece that is divided into 3 spaces.
Be best to use a chemical drain unblocker, Mr Muscle or similar. Possible Caustic Soda. Usually all the hair and grime clog up, chemical unblockers usually do a good job of removing this.
Jan 10, 2010 | American Standard Cambridge 5' Americast...
1991 miata made a noise that sounded like liquid sloushing in the side door.
Sounds like you rear hood drains are blocked.
Do a web search on how to unblock drains on Miata or Mazda MX5
Nov 18, 2009 | 1991 Mazda MX-5
FZA 81 FREEZER-blocked drain
take back panel off inside freezer and you will probably find drain blocked by ice. melt off with a hairdryer and follow up with hot water till it flows freely away. takes a bit of patience
Aug 31, 2008 | Hotpoint Freezers
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
