Question about Tissot Watches
My tissot t touch expert solar e84 have problem with minute hand, i try to synchronize but minute hand cannot move to anywhere, have any solution ?
SOURCE: On my Tissot t-touch expert, i need to know how to change
1. touch middle of screen till you see 24h Cm or 12h Cm
2. press middle button
3. top button changes Cm to Fft (celcius meters to farenheit feet)
4. bottom button changes from 12h clock to 24h clock
Posted on Apr 13, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
SOURCE: how to reset the tissot touch expert? After
hello my tissot watch clock hand are not schronize on the digital number
Posted on Mar 14, 2010
escapement
  • 2334 Answers
SOURCE: t-touch - Tissot is not synchronized
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TISSOT watch manuals. Rate me, please..
Posted on Mar 31, 2010
  • 5 Answers
SOURCE: the digital and hands display different times on my Tissot Touch
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Posted on Apr 26, 2010
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
The digital time display and the hands display don't match
You can try to so the synchronization to match the digital time and the analog hands.
here are the step by step procedure including visuals, click on the link.
I hope this will resolve your issue.
Thank you for choosing Fixya.
Mar 06, 2011 | Tissot T-Touch T33159851 Wrist Watch
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Jun 04, 2009 | Tissot T-Touch T33759851
Synchronizing
This is user-correctable.
See manual page 4, titled "Synchronization".
1. Press T button
2. touch center until you see the 24h/units
3. hold down T for 5 seconds until you see "Synchro" in the LCD.
4. use the + button to move the long hand to 12 o'clock, use the - button to move the short hand to 12 o'clock
6. press T button to commit settings.
Hands will move to agree with the time in LCD.
Dec 06, 2008 | Tissot T-Touch T33759851
Synchronizing digital time with analogue time
hi...
press the T button until the crystal is activated.
press the middle of the glass until the time format appears (24hb Cm appears)
hold the T button for 5secs (SYNCHro appears)
move the hands until they are at 12 o'clock. ( + button moves the minute hand. - button moves the hour hand)
press the T button to set.
digital and analogue time are synchronised
pol
Jun 19, 2008 | Tissot T-Touch T33759851
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Jul 06, 2007 | Tissot T-Touch T33759851
Can't get the watch to synchronize
Your battery maybe down in power ie not much longer before it runs flat this seems to cause the problem you descibe ..otherwise it should set as long as you are following the correct procedure from the manual
Feb 06, 2007 | Tissot T33.1.588.71 Wrist Watch
Watches Logo
21 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
