Question about The Home Security
Digoo camera, disconnect and reconnect all the time... and need to set up dvr
HOW DO I GET MOTION DETECTION TO WORK?
Are you sure the cameras are capable of motion sensing and make sure that you do not need an additional control cable to the camera to make that work.
Jul 17, 2014 | First Alert Home Security
What is the format for the DVR-415 time set?
You will need to connect to a PC, then open the notepad file and change the time carefully. Safe the notepad file and the correct date and time should be set.
May 07, 2014 | SWANN DVR-415 ThumbCam Mini Digital Video...
Factory reset on pro-642
There is no factory reset unplug the camera shut down the DVR then reboot the DVR then reconnect the camera if this doesn't work check the power supply to the camera it might not be getting the correct voltage hope this helps thanx Chris ..
Mar 01, 2014 | SWANN Pro-642 Indoor/Outdoor Security...
Cann't connect to wj-hd716 via network
Hi
in some case, you need to check the compatibility view settings in the Microsoft IE.
- go to "Tools->Compatibility view settings"
- add the ip address of your DVR
- try open the DVR web.
Feb 17, 2014 | Panasonic Wj-hd716/4000 16-ch Real-time...
One ptz camera not responding to controls
Cameras should have a reset button on the unit twords the back bottom, try this and re introduces the camera to the system.
If this does not work, try unhooking the power to this camera and reconnecting it . If that don't work recheck all your software setup and settings to see if something became corrupted. Other than that you may have a bad camera.
Oct 21, 2013 | EverFocus ECOR264-4F1/500 H.264, 4...
Pioneer SC-1522-K
Apart from the obvious one of a dodgy cable or socket. Is there any option on the receiver for assigning devices to any of the ports? Or some king of setting on the receiver to say what that port can be used for? The same to for the device(s) outputting signals to the receiver.
Jul 22, 2013 | Audio Players & Recorders
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
Home Security Logo
Top The Home Security Experts
Lawrence Oravetz
Vernon Taylor
Are you a The Home Security Expert? Answer questions, earn points and help others
