Question about Dishwashers
Hi, Why won't my dishwasher work when the power light is on and so is the control panel? Nothing happens when I close the door. It is model: DIF 04 Type: LS 12-DEA601 S2
catriver
  • 878 Answers
SOURCE: Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Posted on Nov 05, 2006
  • 114 Answers
SOURCE: No power to control panel after power surge
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Posted on Oct 02, 2007
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 171 Answers
SOURCE: dishwasher powers up when switched
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Indesit dif 04A dishwasher
Either: broken wiring at the hinge point o the door
or: water solenoid full of crud.
get a service tech to check it out.
Oct 18, 2013 | Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Sep 28, 2012 | Dishwashers
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
No power getting to the dishwasher. I've checked the circuit breakers and they seem to be working fine. When I try to start the unit nothing happens, no lights, no anything.
Make sure if your dishwasher has a power cord that it is plugged in to the wall outlet under the sink, or open and close the door a few times to try make sure the door switch is getting triggered letting the dishwasher know that the door is closed and the power can go through the switch and power up the control panel, those are just simple quick checks you can do on your own, otherwise you may need a tech to troubleshoot for you. Good luck !
Nov 26, 2009 | Cars & Trucks
I have model # FDB431LFCO My house is 2 years old.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Nov 20, 2009 | Frigidaire Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
