Question about Tefal Irons
The retractable cable will not pull out to plug in my tefal pro express iron
geox29
  • 65 Answers
SOURCE: tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Posted on Jun 21, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
SOURCE: I have a Tefal Pro express iron and I have water
There is a seal or a connection leaking. Take the iron apart -- you'll probably see where it's been leaking.
Posted on May 04, 2009
ercupa190
  • 12223 Answers
SOURCE: as the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Posted on Oct 03, 2012
My Tefal pro iron sometimes makes noise and dont steam any more?
get rid of the calcium,and use distilled water for steam,not tap water
Jun 20, 2015 | Tefal Pro Express GV 8120 Iron
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
Jan 26, 2011 | Tefal Pro Express GV 8120 Iron
Tefal 2932 pro express iron not steaming
Use different water in the iron...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 14, 2010 | Tefal Ultraglide 1549 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Irons Logo
61 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
