Question about Irons
Retractabe cable wont come out from iron to plug in
How do I find out why my singer magic press 4 won't work? no light comes on, no heat
Assuming you have tried different power points in the house, it is likely the mains cable plug of the iron is faulty. Worst the cutoff fuse or control inside has tripped. Would suggest if mains cable or plug is ok then buy a new iron as these can be risky to repair without knowing what one is doing.
Aug 26, 2014 | Irons
Iron not turning on
First check the board plug by connecting other device.
Check the cable from iron to board plug
Nov 03, 2012 | Irons
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
Shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
Nothing happens
Check the cord feed onthe part when it comes to the iron sometimes there got cable broken on the inside
Jun 03, 2010 | Rowenta DX-8800 Iron
My iron stopped working suddenly whilst I was ironing. The light which would normally appear is now off. I changed the fuse but to no avail. How and where can I get it checked?
Hi!!
If you know how to use a VoltMeter, you con fix it.
A very common problem with Irons is the power cable, It temds to wear until it breaks due to constant bending and twisting, it usually hapens at the Iron's end or at the plug end.
Take the cable off the iron and check for continuity while turning and twisting the suspected spots. Replace cable if unsure.
Good Luck
Mar 12, 2010 | Irons
Iron wont turn on
Probably a broken or burnt wire, you need to open the iron and tie or solder the wires back together, it'll be functional again. Good luck
Feb 11, 2010 | Maytag MLI7500A Iron
Iron was working long enough to complete ironing pants.Iron stopped heating up completely. Lost heat completely, I tried plugging it into another circuit but it did not heat up.
Firstly Check the fuse in the plug and replace if blown,if ok it could be your cable ,element or thermo switch.Please come come back if you need further assistance
Aug 10, 2009 | Irons
When plugged in iron will not "turn on." If shaken it will sometimes turn on then shut off again. Appears to be an auto shut-off problem.
Could also be a break in the supply cable inside the cable guide
The cable moves during ironing and as the cable guide is fairly rigid , the inner cable gets stressed and snaps
Try waggling the cable instead of shaking the iron
Jul 06, 2009 | Rowenta DZ1700 Iron
When i am ironing all the power in the house goes off and it is a brand new iron
Patrick,
The iron may actually be ok. If not, remember that because it's new it will come with a guarantee.
Did you put the plug onto the iron yourself? Check inside the plug to make sure that there's no bare wires that can touch as the cord flexes as you iron. This would cause it to short and throw the power in the house.
Try using the iron in a different room. If you get the same problem then there's possibly a wiring fault (maybe a broken/worn insulation on the wires of the iron cord ... though as it's new, I would doubt this).
Are you using an electrical extension lead to plug the iron into? If you haven't overloaded the socket with other electrical appliances it may be that the extension cable has a broken/faulty/loose wire inside that when they touch, causes the power to go off. A few years ago the power in my house used to go off on occasions whenever someone went to the fridge. The fault was traced to split insulation on one of the wires in the extension cable I was using. Whenever somebody stood on the cable it shorted out and cut the power.
To be really sure - go into a neighbours and use the iron! If the power goes off - it's the iron at fault. If not, it's probably just a small problem like worn insulation/loose/broken wire in an extension lead in your own house.
Sep 19, 2008 | Conair Compact Garment Steamer Iron
Irons Logo
55 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
