I NEED A DC MOTOR FOR A JANOME MB-4 EMBROIDERY MACHINE.IM FROM DURBAN. PLS ASSIST
PART NUMBER 770610007
SOURCE: Kenmore 19005
The memory card cannot be over 128 mb. Also the files need to be .jef format and stored in an emb folder on the card. I hope this helps.
Posted on Sep 18, 2008
bargainbox
  • 1388 Answers
SOURCE: embroidery machine janome 300.
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 3 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Dec 28, 2008
  • 5 Answers
SOURCE: need help with transferring designs to machine
Put the cd into your computer drive and open it. Put your usb stick into one of the ports and open it as well. You must have the emb folder on the usb stick to put the designs into. If they are not there already- turn off your sewing machine and put the stick in. Turn on the machine and go to settings, then embroidery. Find the one that says Format. and touch that one and then let it do it's thing.
Once you have the folders on the usb stick- you can highlight the design name you want from the list (cd file) and drag it to the folder on the usb stick. Alternatively... right click on the design you want to move. Select copy. Open the folder on the usb stick and right click inside it. Select Paste. The design should appear in the folder for the usb and then you can take it out of your computer... put it into the machine and find the design.
If I can help with anything else... lmk.
Tracy in Nashville, TN
Posted on Jan 04, 2009
  • 8 Answers
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
Posted on Jan 11, 2009
SOURCE: Using bigger than 64 MB compact Flash Cards
I have the same machine and if you watch the dvd included with the machine it says to use a MC no bigger than 1 gb. I use a 512mb and it works fine. Your computer may not have a MC port so you will have to purchase a memory card reader which you can purchase on ebay or at Fry's for around 10 dollars. All the files need to be saved on the MC card as a SEW or JEF file. When you go to your machine touch the emb. key then the disc key and you should see your files. You may also need to turn the page; sometimes it save it on different pages.
Posted on Apr 16, 2009
Can I use Bernina Embroidery Cards with my Janome MC9500
Getting That Embroidery Design To Your Janome ...
https://tv-sewingcenter.com/janome/getting-that-embroidery-design-to-y...
Aug 21, 2010 - The designs will then be recognized by your embroidery machine, and you will spend more .... you can use either jef or jef+ for your 11000se .... like to know what brand,size and card reader to purchase for my Janome MC 9500. ...... Bernina · Elna · Embroidery · General · Janome · Necchi · Quilting · Sewing ...
Janome MC9500 100 Stitch Sewing 5.5x8" Embroidery ...
www.allbrands.com/products/8905
Janome MC9500 5.5x7.8" Embroidery .jef Format Replaces Memory Craft MC9000 ... to creative quilting and clothing construction, your sewing projects will go ... designcards) or Compact Flash Memory Cards (as used in digital cameras). ... My set screen controls for contrast, In./Cm. designation, and other customization
Which format does my machine use? - Embroidery.com
https://www.embroidery.com/help.ec?docID=225
Dec 26, 2015 | Janome Sewing Machines
While sawing the embroidery holder moves as well, looks like its not falling into its place correctly after embroidery, how can I fix it? Also I've self checked the machine but cant get the zi
YOUR MACHINE USES A PULSE MOTOR (SMALL MOTOR) THAT CAUSES THE NEEDLE ARM TO MOVE. IF THE MOTOR IS A PROBLEM THEN YOUR ZIGZAG STITCH AMONG OTHER STITCHES WON'T WORK. YOUR HOOP I'M NOT SURE BUT IT SOUNDS LIKE YOUR HOLDER ISN'T LOCKING WHEN YOU PUSH THE HOOPS ON. LOOK INSIDE THE HOLE WHERE YOU PUSH THE HOOP AND TOUCH ON EACH SIDE AND PLACE PRESSURE TO SEE IF THEY BOUNCE BACK. ANYWAY, YOU WILL PROBABLY NEED TO GO TO YOUR LOCAL REPAIR SHOP ON BOTH OF THESE PROBLEMS.
Nov 17, 2014 | Janome Sewing Machines
Janome
Sounds like your embroidery unit may have a bad motor or broken drive belt. Get that unit into a repair shop.
Cheers,
Kelly
San Diego, CA
Jul 30, 2014 | Janome Memorycraft 9700 Computerized...
Lost the instruction manual janome decor excell II 5024 Pls email at the following email address
at janome website they have a operation manual
under machines it will show different names like embroidery-sewing/quilting
look for the one that says retired
it will bring up a picture under the picture it will say machines in this catagory
it has a janome decor excell 5124
Nov 24, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Is this machine a high or low shank? I'm trying to buy a 1/4" quilting foot or seam foot and not sure which foot to buy.
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Nov 12, 2009 | Janome 8080 Computerized Sewing Machine
Kenmore 19005
Aug 05, 2008 | Kenmore 19005
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
