Question about Tivoli Audio Players & Recorders
Will any 12 volt power cord fit my tivoli songbook?
    Master:
  • 604 Answers
No,they are different amperages
Posted on Apr 21, 2017
SongBook potentiometer
This can be replaced by a generic control and should be available from any electronics parts supplier. There are two main types of these that differ only in the way they are mounted. When you look for the replacement, you will need to specify the direction of the pins. In other words, are the pins inline with the main shaft or are they at a right angle. Since you are in Italy, I don't know any distributors there, but this should be a common enough part to be found just about anywhere. The indication A20K indicates that this is an Audio Taper valued at 20K which is 20,000 ohms.
Good luck.
Dan
Apr 16, 2008 | Tivoli SongBook FM Radio
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Is it powered thru batteries or 110 volts
If it is a domestic brand dryer, it will run on mains ac power. If it was purchased at a solar or camping store, then it may use 12 or 24 volt dc power, if the latter is the case, it would be clearly marked and the power cord would not fit domestic home sockets, unless it was a second hand machine and had been amateurly modified in which case I would seek an experts inspection.
Sep 30, 2014 | Dryers
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
Someone gave me an old Sylvania monitor (L15) Model no. PD-70FA but the 12V DC power cord is missing. It is not a standard type of powervcord and none of the stores I've been to (Staples, Office Depot,...
The power chord for this monitor is attached to a power adapter which converts mains voltage to 12 volts.
Check the power label on the monitor for the amp rating of the monitor and get an adapter that has an output of 12 volts and with the amp rating on the label or higher. Make sure the 0.3" power plug fits the monitor.
Feb 26, 2011 | Computers & Internet
My black Tivoli Songbook case has become completely sticky. I have only ever used a bit of water and a cotton cloth, what can I do or clean it with? thanks Jodi
Hi Jodi:
Same with both of mine. I used solution of vinegar and water, about 50/50. It seems the "rubbery" texture is now gone, but the terrible sticky is gone also. The solution did not remove any of the lettering or numbers.
Moose in Phoenix
Oct 31, 2010 | Tivoli SongBook Clock Radio
Tivoli radio sticky case
I have the yellow songbook and it was so sticky and dirty after only a couple of years. I only use it inside, so I removed the sticky coating with nail polish remover and a ton of cotton balls. It worked really well on the yellow one - the finish is a little dull so it matches how it looked when it was new. And it's so clean now!
Apr 09, 2010 | Tivoli SongBook Clock Radio
Craig High Definition LCD TV (15.6 in) power cord
The power source is a 12 volt transformer so you can use a standard universal power supply. A 12 volt DC Power Cord with Auto Cigarette Lighter type Adapter will work in an auto.
Nov 03, 2009 | Televison & Video
Open Questions:
Top Tivoli Audio Players & Recorders Experts
Frank Russell
Frank Russell
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
