Question about Roundup Garden
Roundup power 360 SL Who match do you mix per Letter
4 Suggested Answers
  • 15 Answers
SOURCE: Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
Posted on Apr 19, 2010
jyackle5
  • 8197 Answers
SOURCE: How to mix roundup to kill weeds
6 fluid ounces of Roundup (12 tablespoons) per gallon of water.
Posted on May 02, 2010
  • 56 Answers
SOURCE: I need to know How
I use 3 oz. of Roundup to every gallon of water and it kills even the local star thistle. They can be used together with the Krovar ratio at 2.4 oz. per gallon.
Posted on Mar 27, 2011
Mixing ratio roundup
Don't really catch your question, but 30 ml per liter is a good strong ratio. Some labels tell you to mix less, but not all weeds die if a weaker solution is mixed. Some more hardy weeds will not even turn brown. Also check the active ingredient grams per liter Ours are 480g/L. It differs from country to country as well as other suppliers selling it under another name.
Oct 07, 2014 | Roundup Garden
Tip
A convenient way to kill individual weeds in your lawn
I purchase full strength roundup from places that sell fertilizers etc to farmers. I mix my own roundup per their recommendations plus a little. I fill a small eye drops bottle with my mixed roundup. I like this bottle because it has a small opening so I can squeeze out a drop at a time.. I carry the bottle of mixed roundup in my pocket, with the lid shut tight of course, and as I mow and I spot a weed I take out the bottle and place on or two drops on that weed. One drop of roundup on a leaf of a plant will kill it but I try to place one or two drops right in the middle of the plant. Roundup is fed to the root of the plant from the leaf kills the weed from the roots up. This works well because I can kill the weed without killing grass or other plants around it. Wind will not effect it because the roundup is place on the plant not sprayed on it. Roundup needs about 12 hours to work so do not water right away. Ready mixed roundup from a store may work, I have not tried it because I want to be sure the mixture is strong enough to do the job. About 4 ounces per gallon of water is recommended, I increase that to about 6 ounces. Works great.
on Apr 16, 2010 | Garden
I have roundup concentrate plus, what is the mix that I should use?
Roundup should be mixed at a ratio of 3 ounces of herbicide per gallon of water for general use.
May 05, 2011 | Roundup "" Weed & Grass Killer
I need to know How much roundup per gallon of water. Also, can I mix Krovar with it and if so how much per gallon?
Mar 27, 2011 | Roundup "" Weed & Grass Killer
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
Need to know how to mix round up and water
Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 27, 2010 | Roundup "" Weed & Grass Killer
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 25, 2010 | Roundup ScottsRoundUp 0394560 PT...
May 02, 2010 | Roundup ScottsRoundUp 0394560 PT...
How much roundup to 5L of water so I can spray
If you're using pro-roundup or agriculture level roundup mix 1 Cup of roundup to 5 gallons of water. This will give you a mixture between 1% and 2% which will kill most undesirables and anything else that picks up the spray.
Jan 21, 2010 | Roundup "" Weed & Grass Killer
HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
May 22, 2009 | Roundup "" Weed & Grass Killer
Garden Logo
79 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
