Question about Coffee Makers & Espresso Machines
What is the meaning of sublimation heat press?
Heat press machine
    New Friend:
  • 3 Answers
Heat press machine is the machine which is used for printing images or data on fabrics. It is mainly used for promotion or decoration. A sublimation machine is one that can achieve a temperature of 400 F or higher. Any machine which can reach till 400 F is a sublimation heat press. For getting the detailed information you may view here.
Posted on Apr 21, 2017
  • 178 Answers
Its a heating device that is used for putting heat transfer on to articles
example putting logos or transfers onto cups
Not my expertise but i am sure its correct
Hope it helps
Manual for swingman 20e
Hix Heat Press SwingMan 20E: 16"x20" Swing-Away > ... > Heat Press Machines, Inc.Hix Heat Press SwingMan 20E: 16"x20" Swing-Away - MADE IN ... Heat Press 16 x 24 Heat Press by Power Heat Press Sublimation Heat Press ...
HIX Swingaway Heat Presses - YouTube
? 2:30
Mar 7, 2014 - Uploaded by Alpha Supply Co
HIX Swing away heat presses showcasing the Swingman 20P,Swingman 20E, Swingman 15 and the ...
Hix Heat Press Machines For All Heat Transfer Printing ...
Hix is manufacturing heat press machines for more than 40 years! Why Buy From ... If you should see any of these presses we offer advertised for less, we will meet or beat the price! .... Hix SwingMan 20E Manual 16"x 20" Swing-A-Way - Economy ...... Turncaps into walking advertising for your customers, teams, and more!
Hix SwingMan20E Heat Press Machine -
Jan 24, 2016 | Hix Heat Press SwingMan 20E: Manual 16"x...
I have not used my brother DCP-J125 for sublimation for a few months and it does not print now? What can I do?
clean several times your machine by pressing menu ink management clean and all .connect to electricity and open machine long press menu key while opening machine long press menu key until it shows maintenance in black background then press up key near OK bottom it increase number and down key decrease number press up key until there is number 8 then press OK again 0 OK press mono key until it shows Purge after it shows purge then press 2 OK 7 OK 8 OK 3 OK it shows purge 00000 then press stop Key then press 9 OK 9 OK your machine will start automatically. and your machine is ready to use again.
Jul 30, 2014 | Brother DCP-J125
Heat transfer mug without coating
Sublimation Printing is the most common printing method on mugs. By theory, sublimation is offset printing from a transfer paper to your substrate (which is your mug). Mug Coating is important since the coat is composed of Polyurethane paint which is where the Sub-Inks adhere into. Without a Polyurethane coat, the Sub-Inks will not stick to the surface of the mugs. What you can do in order to print on non-coated mugs is to coat those mugs yourself using Polyurethane paints that you can buy at hardware stores. These are usually used in automotive painting and may cause you a bit for each can.
You have to remember though that Polyurethane paints dries longer than enamels and prolonged exposure to these types of paints is hazardous to your health.
It would still be best for you to look for pre-coated mugs to save on production time and, well, efforts.
And yes, I have tried the above tricks personally as I am also engaged in crafts business...
Mar 25, 2014 | Canon Selphy Cp-800 Dye Sublimation...
Freezer too dry
Why is this question in camcorders?
Water can evaporate from ice. This is called "sublimation".
As a result, ice cubes shrink, especially in frost-free refrigerators, which are often very dry. Frost free models have a fan that circulates air internally so the moist air gets blown out, rather than
Freezers get condensation from moist air that gets inside when you open the door. Frost free models cycle off every few hours, and warm up a bit (a heating coil) to melt the condensation and then they blow that out so it won't form frost. They also blow out any vapour from the sublimating ice cubes. Then they cool down again.
Oct 26, 2012 | Video Cameras
Why the sublimation is good than re crystallization?
crystalisation relies on the partial precipitation of a salt based on the difference in solubility at different temperatures.
with sublimation however, you can be assured that all the substance will sublime, just like how water boils completely beyond 100oC
Nov 21, 2010 | Answer Racing Ion Motorcycle Jersey 2010
Add sublimation ink to cartridge for epson c88
The CISS are auto resetebale? If not, you must get a CISS with an autoreset button to get the printer work with the CISS
Oct 06, 2009 | Epson Stylus C88 InkJet Photo Printer
What do I have to do if I want to use sublimation ink on Epson stylus photo 1290?Thanks
what you want is not possible. the Epson Stylus Photo 1290 does not use sublimation ink. it is strongly advised to only use genuine Epson ink to keep the print quality of your print head as high as possible.
Jun 22, 2009 | Epson Stylus Photo 1290 InkJet Printer
Switching from sublimation ink to ultrachrome ink
You can keep the machine, just flush the system fully before loading the new inks.
Jul 25, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
