Question about Dishwashers
My bellini dishwasher stops after 10 mins on normal cycle and lock light and 3hr and 6 hr light flashes,Do you have a remedy
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
SOURCE: Dishlex dishwasher
I have the same problem and the main conrol board was replaced. No Problems since.
Posted on Jun 11, 2007
Amigaman
  • 248 Answers
SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Posted on Nov 22, 2007
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 18 Answers
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
Posted on Nov 21, 2009
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Hello, my Haier dishwasher stopped mid cycle after about 10 mins and will not restart. the lights just flash and buzzer sounds. Can anyone help please?
Have the same problem with mine and have found no solution in the manual or web. four lights flashing and beebs ten times every ten seconds, water coming in and draining out constantly, very frustrating!
Jan 03, 2011 | Haier Dishwashers
May 10, 2009 | GE Dishwashers
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Jan 09, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Dec 29, 2007 | Dishwashers
Zanussi DE6755
This is for the right model, but is the UK version, all should be the same but power supply details might differ if you are in US etc. http://www.serviceforce.co.uk/pdfs/U23297.pdf Hope this helps :)
Mar 05, 2007 | Zanussi 32 in. DE6755 Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
