Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
Power wheels extreme machine just stopped working. New batteries..
3 Suggested Answers
  • 156 Answers
SOURCE: PARTS FOR POWER WHEELS EXTREME MACHINE
You can get your power wheels parts directly through power wheels toll free number, or they will send you to the closest repair center. They should have a complete wire kit.
Here is there website www.powerwheels.com.
hope this helps
Posted on May 19, 2009
  • 65 Answers
SOURCE: where do I get a new wiring harness for a fisher
from fisher price
Posted on Mar 30, 2010
How to operate a wheel balancer phoenix pwb 1530
Installation
Remove Wheel Balancer from shipping crate and pallet.
Place Wheel Balancer on flat and stable floor.
Install the Safety hood.
Install threaded rod to spin rod extruding from side of the machine
using the hex bolt.
If Wheel Balancer shakes or moves while spinning the wheel, it needs to be bolted to the ground to ensure proper function.
Electrical plug is preinstalled to fit North American 110 volt electrical socket.
Plug into proper electrical socket. Do not hard wire directly to your electrical source. There is no power surge protection on the machine. Please use a power surge protector to ensure your machine is not damaged.
Install the wheel balancer in a dry and safe environment. Exposure to moisture or extreme heat can damage the components inside the wheel balancer.
VISIT: http://www.nhproequip.com/PDFs/PWB-1530-Operators-Manual1.pdf
May 03, 2014 | Computers & Internet
My NC10 won't turn on, no life at all. Battery light charge light shows green. any idea's?
Try a atx-reset.
No battery, no adapter and push the powerbutton for 1 minute.
Put in the adapter and try again.
Feb 17, 2011 | Samsung NC10-14G Notebook
I will drive for about a mile with full power with little power lose.then all of a sudden,ill have extreme power loss . within 1quarter mile ill lose all power.something drains the batteries
Batteries do not provide a linear output during usage, but having it die out within a mile or so tells me that one of the battery cells is becoming weaker than the rest. If you're a handyman, you can save yourself a ton of money by replacing only the batteries (try interstate batteries) instead of going to the scooter store and purchasing the batteries and case.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Steering extremely hard, after installation of a new battery
replace the steering pump and it might work better
Aug 21, 2009 | Chevrolet HHR Cars & Trucks
How do I replace power steering pump on my 2003 BMW 325i ?
first Allow the engine to cool completely Make sure all connections have been tightened to the proper torque settings; power steering fluid pumps at an extremely high pressure.Apply penetrating spray to bolts, nuts, and hose connections Chock all wheels that are not raised off the ground. Don't forget to dispose of all used fluids according to local laws.
First, remove the old pump. You may need to raise your vehicle. Use a jack to do this. For added protection, place a safety stand underneath that part of the frame. (Caution: always use extreme care when jacking up your vehicle and putting it on a safety stand.)
If you are working near the battery, remove the negative battery cable. Remove any parts that might get in the way of pulling out the power steering hoses or pump. Drain the power steering fluid from the reservoir. To do this, you disconnect the feed and return lines and drain the fluid into a drain pan, or use a siphon. (You may need special "line" wrenches to loosen the lines if a regular wrench doesn't do the job.) Make sure to loosen the lines before removing the pump mounting bolts. To avoid possible combustion, take care when draining the fluid to avoid spilling it onto any belts or exhaust parts.
Remove the power steering pump bolts. On some vehicles, you can loosen the bolts by placing a socket through the holes in the pump's pulley.
You may be able to return the old pump for a core refund, so drain it completely of fluid and place it in the box from you new pump. To install the new pump, first install the pulley from the old pump onto the new pump, if necessary. Place the new pump in the proper position. If possible, attach return and feed hoses to the pump before bolting it in place. Install pump mounting bolts; torque to specification. (On V-belt models, tighten but don't torque the bolts yet
Attach and tighten feed and return hoses to pump. Double-check all connections for leaks. Reinstall any belts that were removed; adjust belt tension. Tighten V-belt style mounting bolts after you have adjusted belt tension. Reinstall other parts that were removed (shields, brackets, exhaust, etc.).
Fill system with new power steering fluid. Check for leaks. If there are none, place the lid on the reservoir. Reconnect the negative battery cable. Start engine; again inspect for leaks.
You will need to "bleed" the system to remove any air. (Note: bleeding instructions vary from vehicle to vehicle. Check a repair manual.)
Raise both front wheels off of the ground. With the engine running, slowly turn the steering wheel left to right, lightly touching the steering stop points. Check fluid level. Repeat in order to remove all air. After you are satisfied all air is out of the system, lower the vehicle. Job complete
Jul 05, 2009 | 2003 BMW 325
Machine stopped sewing
The thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 28, 2009 | Sewing Machines
Power Wheels only makes the battery connector available as part of the whole wiring harness. There are several parts that Power Wheels will not sell directly to consumers, these usually include the wiring harness, motor/gearboxes and the switches.
If you do need the motors, battery & wiring harness it is most likely not worth repairing. That being said the Xtreme Machine is no longer made by Power Wheels, and the closest thing would be the Dune Racer they now produce. So if you are really wanting the machine repaired you will have to take it to a Authroized Power Wheels service center and have them repair it for you.
The battery you can purchase usually off of Amazon, Toys R Us or from one of the many service centers like us. Power Wheels put two different style batteries into those vehicles depending on the year made. So it may either have 2 6V Red batteries or it might have 1 12V Gray battery. Here is a link to the batteries on our site:
Genuine Power Wheels Replacement 12 Volt 6 Volt Batteries
As for the motors & the wiring harness you would need to contact you local service center. Here is a link to the service center locator: Mattel and Fisher Price Consumer Relations Support Center Power Wheels...
Also before you get too far into this project be sure to look at the new vehicles they make that are very similiar: Power Wheels Products
May 19, 2009 | Fisher Price Power Wheels Kawasaki KFX...
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
409 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
