Question about The Office Equipment & Supplies
I have tray to select that source it can't What what is the problem
How to use the back paper tray for Canon Pixma MG5220 Printer
To use the Rear Tray for your current print job (this should last until you close Word) :
Use Ctrl+P to open the printer window. Click on the Properties button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the OK button.
To permanently set the Rear Tray as the default:
Click the Windows Start button, then click Control Panel and select Printer. In the popup window right click on your printer icon and select Properties. On the General tab, click the Printing Preferences button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the Apply button, then the OK button.
Apr 01, 2012 | Canon Pixma MG5220 InkJet Printer
Can i disable try 1 on this printer
Usually the paper source is set to Auto in Printing Preferences so if you put paper in manual tray it will feed from manual tray and will override the tray 1 selection. If you specifically want to change it to a tray disabling tray 1 you can do so if you go into Control Panel, Printer and right click on the printer and select Printing Preferences and then on Paper menu change the paper source.
Feb 10, 2011 | HP LaserJet 1320 Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
SOURCE DISK EMPTY-- when there is master disk in there
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Jul 26, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
Prints from Manual Tray instead of Tray 4
Open a document. Select File>Page Setup and change the Source to Tray 4.
Or...
Try to print something. When the Print window comes up, select Preferences. On the Print/Quality tab look for the drop down menu labeled "Source is:" and change it to the tray you want. Click on the Save button.
Here is more info from HP:
HP M9050 Tray Configure
Apr 16, 2009 | HP LaserJet M9050 MFP Printer
Lower tray won't work
check your printer properties box to make sure the paper source tray box is set to auto select, also in order to "program" auto select in the printer menu you need to select the enter key and then the "aito select" should then have an asterik next to it, meaning that the "auto select" is now the default.
http://www.websitetoolbox.com/mb/copierquestions
Jan 21, 2009 | Ricoh Aficio SP C410DN Laser Printer
HP PCL5c paper source options for HP M2727
you will find it here
http://www-01.ibm.com/support/docview.wss?uid=nas1ba0863cfa6463903862569c10078c903
HP LaserJet M2727 MFP Series
HP LaserJet M2727nf MFP HP PCL5/PCL6 N hppcl5.pdt
HPLJ4.PDT *RICOHAP3200
*HP5SI
*HP4000 Y Y Y ? PostScript 3 emulation N n/a n/a
Jun 16, 2008 | Office Equipment & Supplies
Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
May 13, 2008 | Konica Minolta bizhub C250 All-In-One...
Selecting a default paper source for a specific program
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Jan 30, 2008 | Lexmark T630 Laser Printer
Printer Tray
Go into the Printer Dialog box from the start button. Right click on the printer and select Properties. Select Printing Preferences. Select the tab for 'Paper'. In the upper right hand corner you can select the paper source, just select tray 2 as the default and save your changes.
Nov 27, 2006 | Sharp AL-1655CS Laser Printer
32 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
