Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Our garage refrigerator is getting old and we wan ted to replace it. 2 people have told us if a newer one is in an area where it gets 40 ior below we may have problems. True? How old must it be to avoid this problem? Sincere thanks!
  • 441 Answers
All of the new one will not work well in a garage. Your best bet will be a unit that is more than 7 years old. If you cant find one try a Hotpoint, this is GEs little brother. The hotpoints have an older design. I use one in my garage Model # HTS18GBSWW You should be able to find this at any appliance store around $500.
Posted on Jul 24, 2009
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
I need to replace the refrigerator from our garage. I bought a simple kenmore with the freezer on the top, only to find out that this type of freezer/ refrigerator will not work in the garage. I need to...
We have the same problem. Sears told us we needed to get a garage kit. It is a small heating element that installs somewhere around the compressor. Cost $20-$30. Just orderd ours today.
Jan 06, 2011 | Kenmore Refrigerators
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Self defrosting fridge/freezer
Good day,
That is normal if the room or area is too cold. If the room temperature drops below 55 degrees Fahrenheit then that problem will start to show up.
All manufacturers state the machine will start to unbalance below that temperature.
Mar 13, 2010 | Bosch Refrigerators
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Garage frig
the garage kit, if even available for your unit, works pretty well, but your right in extreme colds your outta luck, other then buying a refrig designed to work in garage, yoll need to either insualte and heat garage, or wait till spring sorry.
Jan 11, 2009 | Kenmore 63822 / 63824 Bottom Freezer...
Refrigerators used in a garage
Hi pdpup,
Welcome to fixya.com.
I have the solution!
I'm Huuum, at your service
I just got back from our buying groups Sept. appliance show where we saw the answer to all these refrigerators that can not be in the winter garage any more.
Frigidaire just came out with a convertible upright 17cu. ft. freezer/ refrigerator.
All year it is a refrigerator and just before it gets real cold you convert it to a freezer with a touch of a button until spring.
Model # FKCH17F7HW
We should be able to get it soon.
A couple of weeks I was told!
It is not in their web site yet but I saw it in action and I believe that Frigidaire is the only on at the moment that makes this!
You can call them and track the stock and when it will be in your area!
Now that's service,
Thank you for using our service
Please remember to give me a solved rating before you sign off!
Huuum
Sep 23, 2008 | Refrigerators
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
Refrigerator not cool enough in garage.
if the unit is not in an area that falls below 65 degrees f then he is wrong, if the unit is in an 80 degree envorment then there is a problem with the unit possible sealed system leak 1st i would check, second a defrosting issue third fans running
unit can be serviced in the garage, the tech is incorrect
May 27, 2008 | Kenmore 60721 Refrigerator
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
241 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
