Question about Goldstar Refrigerators
Where is the control panel for fridge in goldstar 21ft ensuite caravan
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 | Home
What is the replacement for Goldstar GR-3423DRI fridge's defrosting timer as I cant find same one
Check with a local appliance parts supplier to cross-reference into an equivalent part.
Jun 13, 2016 | Goldstar Refrigerators
Mini fridge working
Sounds like it needs a new thermostat.
Apr 03, 2014 | Goldstar Heating & Cooling
My goldstar dehumidifier does not shut off when full, cannot adjust the control panels
There has to be a float switch or sensor that detects the full condition. You may find that the non-functioning control panel is the cause of the problem so the next step is to find out why the control panel does not work.
Sep 10, 2012 | Goldstar DH504EL Dehumidifier
What is an Ensuite?
Ensuites are designed to provide you with a private room or as a toilet or shower cloak. Ensuites are available in either single or double size and come with a unit supported with poles. There are some ensuites with features like removable roof for use with a solar shower, removable floor, storage for toiletries, hook for a light and mesh windows.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
I have a Goldstar small refrigerator GR-151SPF which is presently freezing the contents. Please tell me if high or low numbers make the frig colder. Thank you.
Hi and welcome to FixYa, I am Kelly,
Warmest settings are CCW and COLDER settings are clockwise on the control. Use the numbers as a reference point but... CCW = warmer Clockwise = COLDER
Thanks for choosing FixYa,
Kelly
Feb 25, 2011 | Goldstar Refrigerators
What do i set the valves to on my 98 jeep cherokee; just put on a new head
HI, There is no valve lash spec for your Jeep they are non adjustable. You will just tighten the rocker arms down to 21ft. lbs. I usually do them in two steps 15ft lbs first then come back and finish at 21ft. lbs. This just gives the lifters a chance to collapse slower. Good luck and happy motoring.
Sep 13, 2010 | 1990 Jeep Wagoneer Limited
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Sep 11, 2006 | Goldstar MV-1526 Microwave Oven
Refrigerators Logo
Top Goldstar Refrigerators Experts
AJMAL KHAN
Tom Chichester
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
