Question about Dryers
I have a electric motor out of a clothes dryer pulled the motor out it has a start cap not sure how to wire this up so it runs the motor is 240 volts 1/8 hp cheers
  • 142 Answers
SOURCE: Kenmore Heavy Dut Model 86427810 runs but does not heat
You need to have a look at the thermal protection devices and the thermostat section and make sure they are functioning such that power is reaching the heating elements. If they are and there is still no heat, the elements are probably malfunctioning. If the dryer is producing ANY heat, then the thermostat and thermal circuit is OK, and all you need are elements.
Posted on Apr 16, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: What size breaker do I need for a 240 volt electric clothes dryer
check on the wiring diagram. You may be looking at 2-15 amp or 2-20 amp breakers.
Posted on Nov 12, 2008
  • 118 Answers
SOURCE: Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Posted on Oct 27, 2009
  • 33 Answers
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Posted on Oct 28, 2009
  • 89 Answers
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
Posted on Nov 01, 2009
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
I have a Whirlpool gew9868kl3 dryer. The dryer only clicks when you try to start it. I did the diagnostic check on it and I do not come up with any errors. I did however find two things during the check...
one of 3 things can be wrong 1) make sure on an electrically heated element dryer that you have 240 volts,because if not either the timer or motor wont turn and it will not heat without 240 volts,2) if you can hold the start switch in the start position and you can hear the motor running then its a broken belt and there is a switch on the idler pulley tensioner bracket to stop the motor so if the drum wont turn the unit also wont heat to protect against overheating clothes starting a fire. 3) if no sound then either the motor switch is bad or there is a wire off the motor start switch which is very common due to vibration
Apr 12, 2011 | Whirlpool GEW9868K Electric Dryer
Why does my kenmore dryer not heat up
Why does my Kenmore dryer not heat up.
There are several causes, but the most common one is the heating element. Before we diagnose that lets get down to the rock bottom of basics. An electric dryer runs on 240 volts, like a AC system. So
240 volt systems use two circuit breakers. The heating element in the dryer works on 240 volts. The motor and all the other control parts work on 120 Volts. Just like the other electrical items in your house. So the first thing to do is Check the circuit breaker. A circuit breaker for a dryer has two switches linked together with a cross bar. (or it has two large fuses in which one could be blown) It is possible for 1 of the two switches to be tripped.
Locate the breaker for the dryer. Switch it completely off. Wait 20 seconds and turn it back on. If it won't go on, there is an electrical short in the dryer wiring.
Now we are going to check the heating element. But first, REMOVE ALL OF THE CLOTHES IN THE DRYER. Now turn it on and see if there IS heat when it is empty. If there is IS heat. Then the problem is a clogged, or pinched-shut vent hose in the back. In this case, the moisture in the clothes has no place to go, so it stays in the cloths and they stay wet. If this is the case, pull the machine out from the wall about 8 inches. look down at the hose from the back and make sure it is not crushed. Now see how it dries with the clothes in it.
Let's say it is still not hot. Now we are normally looking at a special white colored fuse that is
mounted inside in the rear. Or a blown heating element that is mounted in the same area.
This repair at this point would normally require a professional technician. BUT if you want to do it, let me know and I will advise you of the steps. Hope this helps,
Best, Mark
Dec 29, 2010 | Kenmore 63942 Dryer
How to install new circuit breaker, wiring, and outlet for washer and dryer
Electric dryers require both 240-volt and 120-volt circuits in order to work. The 240 volts are used to heat up the elements that ultimately dry your clothes and the 120-volt circuit is needed to deliver power to the timers, buzzer and controls. This does not mean that you have to run two independent circuits, however. All that is required is a dryer receptacle fed by a three-conductor wire or 10/3g wire. Here is how to wire a dryer receptacle.i think it will work.
Dec 16, 2010 | Dryers
My dryer is drawing 22 amps, the drum is turning fast. I am getting no heat for the clothes. The voltage is 240. I would like to see a manual so I can see if a belt is off or not. Thanks Tony
My guess is that the power socket in the wall for the dryer is incorrectly wired! 22 amps is about right for a functioning dryer, but not just the motor. The drum is turning, so the one belt is intact. First thing to check is the voltages at the socket. There should be 240 volts between the two slanted connections, and 120 volts between the center vertical connection (neutral/ground) and either slanted connection. I'm guessing that the 120 volt motor has 240 volts across it accounting for the fast drum speed. If the socket checks ok, check the wiring of the cord inside the dryer. The center wire of the cord should go to case ground. Hope the motor wasn't damaged.
Jul 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Nov 12, 2008 | Fahrenheat Electric Convector Baseboard...
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore 86980100 dryer no heat
NO HEAT, CHECK THE FOLLOWING:
1. CHECK SETTINGS OF THE SELECTOR SWITCH. MAKE SURE A HEAT SETTING HAS BEEN SELECTED.
2. IF IT IS AN ELECTRIC DRYER, CHECK FOR 240VOLTS AT THE OUTLET.
3. CHECK THE HEATING ELEMENT FOR 240 VOLTS AT THE TERMINALS OF THE ELEMENT WHILE THE DRYER IS RUNNING. IF NO 240 VOLTS, TRACE WIRING BACK TO OTHER COMPONENTS OF THE HEAT CIRCUIT. WHEN YOU FIND 240 VOLTS ACROSS THAT COMPONENT, THAT IS THE BAD ITEM.
4. CHECK FOR BURNT WIRES IN THE HEAT CIRCUIT. (HEATER, THERMOSTAT, HIGH LIMIT THERMO, MOTOR CENTRIFUGAL SWITCH, TIMER, THERMAL FUSE).
Apr 21, 2008 | Dryers
Dryers Logo
Top Dryers Experts
