Question about Koss Audio Players & Recorders
Hi I need a number of the integrante amplifier of the koss ms513
Does the ks3102 need a stand alone receiver to make surround sound?
Hi, It all depends on the system you are using. Most sound systems sub woofers comes with in built Amplifier, So if the system your using does not have amplifier to amplify and make the sound system sound better,That means, you will have to get a receiver for your system for great performance.
Hope that helps.
Thanks for using fixya....
Nov 27, 2010 | Koss KS3102 System
I need a replacement remote for a Koss KS 4192
hi! i have here a couple of codes for KOSS home theater system, just try them 4003, 2060, 4015, 2200, hope this helps!!! goodluck!!!
Jun 09, 2010 | Koss KS4192 System
Koss td-61 headphones - ear cushions are disintegrating - little black plastic flakes coming off - how to replace them?
Koss offers a limited lifetime warranty. They may replace them for you. See:
I have the same problem with my UR30 which have not been used very much and this is the path I'm going to try. Good luck!
Jan 10, 2010 | Koss TD-61 Headphones
Need the code for a Panasonic TV remote to operate KS3102
I found a few manuals that may have a similar model number but none of them contain the Koss Receiver, you may want to try a few random receiver numbers and see if anything works, these are all the universal codes i could kind for koss receivers:
Mar 06, 2009 | Koss KS3102 System
Home theater koss KS3102 need code to unlock it
heres your answer,,, follow this
I tried this, and it works prefect.
1) You do not need to have any disc in the player.
2) Press "menu" "1" "6" "7" "1" "9"
A special menu will appear with cursor pointing at region.
3) Press "OK", and the current region number is disappear.
4) Press "0", and your player now is region free.
Jan 22, 2009 | Koss KS3102 System
Cdr200 recording
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Jan 09, 2008 | Koss CDR200 2-Disc CD Recorder
Audio output
you should be able to connect any pc to any home stereo device. you will need a special cable to connect them though. usually a local radio shack or circuit city type store will be able to help you. You will need a " Stereo Headphone to Stereo RCA " cable. ask someone at the store for one of these, explain what you are trying to do, and they will likely be able to help you as well. after you get this cable you can simply plug your computer into the back of the Speaker amplifier (usually called aux or line1) where there will be a red and white plug. set your amplifier to the Aux input and listen away.
Aug 13, 2007 | Koss C220 System
27 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
