Question about Mission 700 Main / Stereo Speaker
Blown fuse in mission 700as subwoofer
I keep blowing the fuse when a signal is sent to my mission 700as subwoofer. Any ideas what to look for or to do?
  • terry994 Jul 26, 2009
    The subwoofer has worked for several years. It is now blowing fuses everytime a signal is sent to it. The last solution from sob_3 seems to think that I am talking about two speakers. The impedence could be the problem but the impedence was fine for several years. Now it has changed? Is there anything else inside the subwoofer that I can check/fix before taking it to a repair shop?
    Problem Solver:
  • 10 Answers
If you have access to a multimeter, you should test you impedance (ohms) Ω, check to make sure the speakers reads higher than the amplifier needs; this will result in less strain on your amp and diminishement of sound...For example: if you connect two 4Ω
speakers in series it results an 8Ω circuit (least strain). and if you'd take the same two speakers and connect them in parralelle it would result in a 2Ω circuit (most strain).
Posted on Jul 24, 2009
  • sob_3 Jul 31, 2009
    from my research, (most common probleme with this model) this could be a faulty relay (instead of kicking in the next power phase, the relay probably has no contacts left to it or somehow became sticky [wrong type of lube or none] and blows the fuse....)
    I can't be sure on that... I'll keep researching...
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
My Mission MS10 subwoofer keeps blowing it's fuse. Possible problems?
Anything in the power supply will cause it, look for damage or burnt parts, anything on heatsink. A transistor with a short circuit. For instance if you put an ohm meter probe to the leg of one and the other probe on to another leg, it will be read on the meter as if you had put your probes on the same leg.
Jan 11, 2010 | Mission MS8 Subwoofer
T2.5amp fuse keeps blowing
the fuse keeps blowing because the amp or power supply is blown up. It needs to go in for service. Pro Line Music 215-736-8055
Dec 11, 2009 | Mordaunt Short 309W Subwoofer
Subwoofer blowing internal fuse as soon as you power up
check your bridge rectifier if no short,audio stage is blown
Jul 15, 2009 | Mission M-CUBE System
Mission 752F blown driver
I would try ebay first. If not follow this link to see if they can help you out. Mission ltd is located in the uk. http://www.mission.co.uk/
Nov 28, 2008 | Mission MS752F Speaker
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Jun 01, 2008 | Acoustic Research AR1 Speaker
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
Mission 700 Main / Stereo Speaker Logo
784 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
