Question about Pacon Office Equipment & Supplies
I'm after Pacon Construction paper. Do you have it in stock?
I can't get calendar creator version 8 to print
Calendar creator is proprietary, i.e., it only recognizes paper stock, size, finish, etc., in it's catalog. If your printer isn't set up correctly, CC throws an error...
Oct 02, 2012 | Broderbund Calendar Creator 8 Full Version...
Spark plugs question
DR8ES is the stock plug for your bike. The heat range is the same on both plugs, The "A" designates a special tip construction. The "S" designates standard tip construction. Bottom line is The DR8EA is a higher priced plug and it will work fine.
Can I get a “very helpful” rating on this answer?
Aug 20, 2009 | 1988 Suzuki GSX 600 F (Katana)
The printer will not pull card stock paper through. It will print on regular printer paper but will not pull the card stock paper for business cards through. What could be causing this?
Usually the stock is too thick to process properly.
Go to a lighter stock or buy a more robust printer if you are going to do a lot of that type of work
Aug 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
I have Printmaster 10 and 17. On 10, I can print to the edges of the labels and others things, on 17 I can't. I know that I reconfigured 10 to do this, but it was years ago and I can't remember the step...
Custom Paper Wizard PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard. Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
  1. In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
  2. In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
  3. If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
  4. Click Next.
  5. In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
    NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
  6. Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
  7. Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
    NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
  8. The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
  9. Click OK.
  10. To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
NOTE: If the paper stock that is added does not display in the list, click or go to Custom Paper Stock Does Not Display (Technical Note ID: 43399) for additional information.
Using the Custom Paper Wizard Tutorial
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
  1. Launch PrintMaster® 17.
  2. Click Help on the menu bar and select Help Center.
  3. Click the View or Print Tutorial icon (light bulb).
  4. Under Choose a Category, click Program Tutorials.
  5. Under Choose a Topic, click Using the Custom Paper Wizard
Oct 13, 2008 | Computers & Internet
Top Pacon Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Pacon Office Equipment and Supply Expert? Answer questions, earn points and help others
