Question about Car Audio & Video
Sumac her sc600a battery charge, I hook it up according to manual, I get a reversed cable signal. What color of clamp goes to wire with white stripe?
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
  • 93 Answers
SOURCE: denon 1905/785 - lost color feeding tv
Your Denon 1905 might be setting it under HDMI for video source.You need to correct it by going to menu,as you browse through the setting,you should able to find video select or video output. It is on the manual.
Remember,you need to run a composite video cable from the video output behind your receiver to your TV video input for this step.
solutiondoct
Posted on Nov 06, 2008
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
etirbynnor
  • 655 Answers
SOURCE: ok, here is a list of the factory wires coming
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Posted on Aug 12, 2009
Testimonial: "thank you greatly. that does help alot."
SOURCE: I hooked up the wires according to the diagram but
just buy a scart plug and stick it in that should resolve it
Posted on Oct 18, 2009
What wire color code (function) on a clarion arx5170 stereo
red wire is live (battery) yellow wire live only when ignition is on, black wire is earth(car body) there should also be 4 pairs of wires green,white,grey and purple these are your speaker wires you'l notice with the pairs of same colour eg white one is solid colour one has a black stripe the solid colour goes to live + on your speaker the one with stripe goes to - on speaker, same goes for the rest of the pairs hope this helps
Mar 31, 2014 | Cars & Trucks
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
I have a new license plate cover with brake lights and turn signals, but i cant figure out how to connect the wires on my 2004 honda rune motorcycle
These are the wire colors and what they each do on the rear end of your Honda: Green is always ground. Green with a red stripe goes to the brake light. Brown with a white stripe is for the tail light. Light blue goes to the right turn signal. Orange goes to the left turn signal. If you need a power source for a license plate light, hook that to the brown/white tail light wire.
Now take your new setup and find out what each wire hooks up to, using a continuity tester. Place the test lead on a wire and place the other test lead in each light bulb socket until continuity is confirmed. Use some masking tape and a pen to label each wire's function. Note that the tail/brake light socket will have two contacts inside.
Mar 06, 2010 | 2004 Honda Valkyrie Rune
Have hand control wireing problem ,,,, need to know what color wire does what ,,,, got the left hand control to wire up on a older bike,,,,, hooking up trun sigals and head light control,,,,what color...
This information applies to the vast majority of Honda motorcycles. Colors for the right handlebar switch are: Grey sends power to the turn signal switch. Light Blue goes from the turn signal switch, to the right turn signals. Orange goes to the left turn signals. Light Green goes to the horn button.
The left handlebar switch: Yellow With Red stripe goes to the starter button. Black wires take power to the headlight switch and the kill switch. White goes to the headlight low beam, Blue to the high beam. Brown / White goes to the tail light, running and instrument lighting. Black / White comes from the kill switch and delivers power to the ignition coils.
I hope this helps.
Nov 06, 2009 | 1982 Honda VF 750 S
Wires mixed on alternator
If you can give me color of wires you have. My manual is showing about 10 different combinations, depending on whether it has electric choke, idiot light or gauge, ammeter in dash etc. Main wires are Orange, or orange with light blue stripe, goes to FLD on alternator, white with black stripe goes to STA on alternator, and BAT terminal should have a black cable from battery. Be careful, there in case someone changed it to red or another colour , just be sure it's coming from battery, and it may have wire from reulator joined into it.It also shows a ground from regulator to alternator too, so just in case it's black too, don't mix those 2 up.
This may do it, but if not, get back to me.
Oct 26, 2009 | 1978 Ford Granada
Want to know what color codes are on deh-p545W, looking for the speakes wire codes
What codes are you looking for ? Is that the speaker wire colors are grey/grey w/black stripe, white/white w/black stripe, purple/pruple w/black, green/green w/black stipe. The black stipe wires is the negative. If you don't have tags on the wires that say; LR,LF,RR,RF. There is another way to find which speaker wire goes where. First hook-up your Battery and Accessory and negative wires. Then just go in the unit and find the balance and fader control. Then just do one side at a time; like front left, rear left and so on....
Jun 04, 2009 | Car Audio & Video
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
