I have a Lennox HP26-024-7P but no operator manual for the Lennox (heatcraft) 7 Day heatpump thermostat prog instructions May 6,1997. Can you help me find a manual online?
5 Suggested Answers
  • 34 Answers
SOURCE: I have lost my instruction manual for my Heller DT2SL
LOOK ON INTERNET UNDER MAKE AND
MODEL NUMBER.
Posted on Jun 21, 2009
slave2aslave
  • 302 Answers
SOURCE: Need conversion Instructions for Storkcraft Lennox Crib
Vancouver-based manufacturer Stork Craft is voluntarily recalling more than a million baby cribs in Canada and the United States over a potential suffocation hazard.
The cribs were manufactured in Canada, China and Indonesia between May 2000 and November 2008, the company said in a release.
About 494,000 of the cribs were sold in Canada and 535,000 in the U.S. in several retailers such as Wal-Mart, Kmart and J.C. Penny, as well as on several websites, including Amazon.com, Babiesrus.com, Costco.com and Walmart.com, the U.S.Consumer Product Safety Commission said in an advisory Tuesday.
This is why it's taking so long for them to respond.
They are very busy. When you do get through to them you may be entitled to a replacement or free parts.
Posted on Sep 24, 2009
SOURCE: I have just moved home
Push run program for a preset schedule, once in the schedule you can change times via up/down temp buttons, push next to set next schedule period and so on. Otherwise push hold temp or hold to overide the program and run as a regular stat, for more info 1800 honeywell or Google support.
Posted on Nov 01, 2010
hvac1960
  • 2133 Answers
SOURCE: i don"t have the manual for the garrison/noma 7
Please follow the video:
HowTo Program Your Thermostat
http://www.youtube.com/watch?v=s2gg8jaddto&NR=1
Hope, helpful?
Posted on Jan 21, 2011
Does a y2081 lennox thermostat have a batteryin it
Yes it has 3 AAA batteries.
Pull it straight off the wall. Look at the back of the thermostat and replace the three batteries.
Link to manual..
http://www.lennox.com/pdfs/manuals/Lennox_Elite_Touchscreen_Manual.pdf
Sep 10, 2014 | Lennox Y2081 ComfortSense 7000 Thermostat...
I need instruction for the timer
You posted under Woods 59403 timer
If this is not your timer, add a comment.
59403 timer manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
If you have different Woods timer, look at images at link below to identify timer.
Add a comment if you need help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Plug lights into timer.
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
Dec 02, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I would like to have the instructions for operation of the Timer.
Add a comment at any time
59403 timer manual:
Set clock:
Program timer:
This is Event1 ON
This is Event1 ON
This is Event2 ON
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
How do I delete one of the set programs on my utiltech 7-day digital timer? The directions say press the mode key, and keeping it held down, press the program key, it doesn't work. Any suggestions?
Clearing event on Utilitec 7-day timer:
Tiny print on instructions say: press PROG button several times to locate setting you want to clear > Press and hold MODE button > press PROG button to clear setting > to finish, press CLOCK button and display will show time of day.
In case of operational failure:
Tiny print on instructions say: press RESET button to clear all settings >> and then reprogram
Sep 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I bought a house with a Hunter # 44100A programmable thermostat but have no manual to program it from. How can I program it?
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Aug 17, 2010 | Hunter Heating & Cooling
How to wire rth3100c to tempstar heatpump
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 26, 2010 | Heating & Cooling
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
