Question about Tablets & eReaders
Kindle fire stuck on reboot logo - Tablets & eReaders
My kindle fire overheated while charging now it won't turn on. It goes to the amazon logo then gets stuck on the fire logo.
You may be able to use a fast-boot cable for the fire tablet, google fast boot cable for Amazon Fire Tablet and see if its uses fit your need.
Mar 01, 2017 | Amazon Tablets & eReaders
Kindle fire wont load past the fire logo
If you need any assistance you can Kindle.com/support Or you can directly call them (877-690-9305)
Dec 20, 2016 | Amazon Kindle
My kindle fire hd apps are saying the licence needs to be refreshed how do i do this?
How do you refresh the license on a Kindle Fire?
First make sure the Kindle has a good Wi-Fi connection and can connect to the Internet. Then do a restart by holding the power button down for about 15 seconds, until you see the "Kindle Fire" logo appear. Let it reboot then open it and see if that fixed the problem.
refresh license - Amazon.com
https://www.amazon.com/gp/help/customer/forums/kindleqna/ref=cs_hc_k_tv?...Search for: How do you refresh the license on a Kindle Fire? https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=kindle%20fire%20hd%20apps%20are%20saying%20the%20licence%20needs%20to%20be%20refreshed
Nov 29, 2016 | Tablets & eReaders
Have the Kindle HD 8.9, was working fine then without action, totally shut down. Attempted charging battery, no go, attempted reset by holding on/off button, no go, attempted resetting by pushing rese
Check the Kindle help page and see of there are any options. There may be a way to do a hard reset which could fix the problem. I've had phones with this issue.
http://www.amazon.com/gp/help/customer/display.html/ref=hp_201016150_web?nodeId=201016150
Nov 03, 2014 | Amazon Kindle Fire 8gb, Wi-fi, 7in - Black
Forgot password to my kindle fire. How do I reset
1 Connect the Kindle Fire to your computer using a USB cable.
2 Wait for your computer to recognize the Kindle Fire device, and select the option that allows you to view the contents and data stored on the Kindle Fire.
3 Copy or move the Kindle Fire files you want backed up over to your computer's desktop or other location.
4 Right-click on the icon for your Kindle Fire located on your computer's desktop, and select "Remove" or "Eject."
5 Remove the micro-USB cable from your Kindle Fire. After you reset your Kindle Fire, you can follow these same steps to move your saved files back to the Kindle Fire from your computer.
Part 2 Reset the Kindle Fire
1 Tap on the "Quick Settings" icon on your Kindle Fire. The icon is shaped like a wheel, and is located in the status bar at the top of your Kindle Fire.
2 Tap on "More."
3 Tap on "Device."
4 Tap on "Reset to Factory Defaults."
5 Tap on "Erase Everything." Your Kindle Fire will reboot, and display a message that confirms the reset process.
When the Kindle Fire has finished resetting, it will reboot once again, and display the initial start-up screen.
Oct 02, 2014 | Tablets & eReaders
Kindle hd stuck on reboot
Try a hard reboot:
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
Nov 22, 2013 | Tablets & eReaders
Kindle fire hd will not switch on
Try a hard reboot:
Sep 23, 2013 | Amazon Kindle Fire HD
Rebooting
If I understand you correctly, the Kindle is stuck in Freetime even if you reboot the Device.
1. Press and hold the power button for 30 full seconds
2. Wait 5 seconds
3. Press and release the power button normally, the Kindle should have exited Kindle Free time.
4. If the Kindle is still not exiting Freetime, proceed with a Factory Reset.
May 06, 2013 | Amazon Kindle Fire HD
You know how when you start your kindle fire up and it says kindle fire. well mines is stuck like that and i cant unfreeze it
Press and hold the power button. If it prompts to shut down, ignore it and keep holding the button. It should turn off after fifteen seconds or so. Release the button, then press and hold for two seconds or so. It should start up and reboot. Does it?
Apr 14, 2013 | Amazon Kindle Fire HD
Tablets & eReaders Logo
44 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
