When u push menu on remote pillow how do u move it up n down
Which pillow do you use?
Most of the time I prefer to use down pillow because it is providing me the best sleep when came to my home after lots of stress. This pillow comes with so many brands so nowadays I am using Hungarian goose down pillow. It gives me great comfort and it prevents me from different types of allergies because it is the anti-allergic pillow.
Feb 08, 2018 | Washing Machines
What is the difference between normal pillows and goose down pillows?
A normal pillow is made of cotton/linen or synthetic fiber. Whereas a Goose Down Pillow is made out of the finest feathers of geese. You can't even match the level of comfort provided by goose down pillows over normal pillows. I have been using this pillow for last one year. It provides the best support to head and neck and is also beneficial for the cervical disease patients.
Feb 08, 2018 | Cars & Trucks
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
My tv rca model # 32668 is in a different language, I need to change it back to English without the remote. Please help
Hello there ,
The user guide can be downloaded here
From the page 28 of the guide.
1) Push 'menu' button of front panel of tv.. This will bring up the menu on the tv screen..
2) Using the 'ch' buttons next to menu button, move up or down to highlight number 8 'setup'
3)press 'menu' button again then 'begin setup now' should appear and be highlighted.
4) Press 'menu again which will take you to 'language'
5) use the 'ch' buttons to move up or down to highlight 'English'
6) press 'menu' again to select english as the language.
That should be it.
If you get problems, read the user guide and follow it carefully.
Good luck
Sep 12, 2014 | Televison & Video
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Resetting lock and accessing menu with universal remote
For these tvs you have to unplug them for three hours to reset them. When you are able to access the menu if the remote control is not allowing you to move up and down left and right usually channel up is up channel down is down volume - is left and volume + is right. If worse comes to worse you can get the original remote from Sharp for $42.50 +tax and shipping by calling 1.877.674.2832 or from for $39.65 at 336-377-2220. The remote can always be returned if having it does not fix your problem.
May 05, 2010 | Sharp 13VT-K150 13 in. Combo
Tv stuck on menu
These Orions and the Emerson units built by Orion all revert back to set up after being unplugged for a given length of time. The situation can be rectified on the front panel without the use of remote. Please forgive if this seems over-simplified:
1. Turn on the set.
2. When screen appears push "FF" or "REW" button to select the desired language.
3. Push "PLAY" to move the arrow down to "Auto Preset".
4. "FF" to engage the auto channel programming.
5. When the set is done auto-programming the menu will clear and you use the set normally.
Jan 14, 2009 | Televison & Video
Tv vcr combo cannot program tv
Try pushing the volume buttons in the middle so that you are mashing both the up and down button, your menu should appear. then you can use the channel buttons for moving up and down.
Dec 02, 2007 | Emerson EWC1902 19 in. TV/VCR Combo
Remote Difficulty
Looks like you are in trouble may have to buy origional remote.there are certain programmable remotes out there which give every function of the origional.most service centers have them,they have to be programmed by computer to suit each individual set.
May 16, 2007 | Pioneer PRO-1009W 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
